LS Dyna
LS Dyna
How to secure analysis stability when using AutoDyn solver
    • Bob
      Hi all
      I'm performing a collision simulation using AutoDyn. I would like to simulate two balls collide as follows:
      However, the simulation diverges too easily, with the error 'time step too small'.
      I want a stable analysis rather than an accurate analysis.
      For a stable analysis, how can i simplify the simulation?
      For this purpose, i tried the following:
      • Element size: Increase the size of too small elements to set the time step appropriately
      • Mesh quality: Analysis settings so that elements are distributed more evenly
      • Mass scaling: Use a stable time step by artificially increasing the mass of small elements
      • Manual time step setting: Avoid stability issues by manually setting the time step
      • Adjusting physical properties: Adjust the physical properties of materials such as 𝐸, density
      • Reducing non-linear effects: Reduce non-linear material modeling to reduce computational costs
      But, all attempts failed.
      Any other suggestions?
    • Chris Quan
      Can you check Energy Summary to see if hourglass energy is high, comparing with Internal Energy?
      What meshing method you used to generate the mesh?
      What is the material of these two balls: ductile, brittle, hyperelastic, or porous?
      What is the impact velocity?
  • The topic ‘How to secure analysis stability when using AutoDyn solver’ is closed to new replies.
