Systems
Systems
Topics related to Twin Builder, medini analyze, VRXPERIENCE and more.
How to save file as Ansys Mechanical Models (*.spm)
    • andr1nik2937a
      Hi everyone,
      I just started working with ANSYS Twin Builder and I’m having a problem generating a ROM.
      As I understand it, I can import a Static Structural analysis (for example) into the Digital Twin module in the following order:
      ROM → Product-Specific ROM → Mechanical.
      However, it requires a specific file type: ANSYS Mechanical Models (*.spm).
      I’ve looked everywhere, but I can’t find this file type in the “Save As…” or “Export” options in ANSYS Mechanical.
      Could anyone please help me with this?
      Thanks in advance!
    • mrife
      Hi andr1nik2937a
      The process is discussed in the Mechanical help here.
      Mike
[bingo_chatbox] ; jQuery(".user-experience-select").select2({ data: data, minimumResultsForSearch: -1, escapeMarkup: function(markup) { return markup; }, templateResult: function(data) { return data.html; }, templateSelection: function(data) { return data.text; } , dropdownParent: jQuery(".user-exp-outer") }); jQuery(".user-experience-select").select2("val", "https://innovationspace.ansys.com/ais-experiences/"); var timesClicked = 0; jQuery(".user-exp-outer").click(function(e) { timesClicked++; e.preventDefault(); if (timesClicked%2==0) { //run second function jQuery(".user-experience-select").select2("close"); } else { //run first function jQuery(".user-experience-select").select2("open"); jQuery(".user-exp-outer").addClass("active"); e.stopPropagation() } }) jQuery(document).on("click", function(a) { if (jQuery(a.target).is(".user-exp-outer") === false) { jQuery(".user-exp-outer").removeClass("active"); jQuery(".user-experience-select").select2("close"); timesClicked = 0; } }); jQuery(".user-experience-select").on("select2:select", function (e) { if(e.params.data.ais=="true"){ window.open(e.params.data.id,"_self"); } else{ window.open(e.params.data.id); } }); });
