TAGGED: ansys-mechanical, drop, lsdyna, lsdyna-lstc-centos-linux
December 16, 2024 at 9:30 am
752612542
Subscriberhi all,
When I use Mechanical for drop testing in Linux, I use pymechanical to read the geometry file:
mechanical = pymechanical.launch_mechanical(exec_file=workbench_path, verbose_mechanical=True, batch=True, loglevel="DEBUG", log_file=True, log_mechanical="pymechanical")Â
geo_import_format = Ansys.Mechanical.DataModel.Enums.GeometryImportPreference.Format.AutomaticÂ
geo_import_preferences = Ansys.ACT.Mechanical.Utilities.GeometryImportPreferences()
geo_import = Model.GeometryImportGroup.AddGeometryImport()
geo_import.Import("{geo_path:s}", geo_import_format, geo_import_preferences)
xxxxxx
dyna = Model.AddLSDynaAnalysis()
xxxxxxxx
However, I recently learned that directly importing the geometry file into Mechanical and then using LSDYNA is incorrect. Could you please tell me how to complete the drop test using a Python script?
December 16, 2024 at 9:49 am
752612542
SubscriberOn Windows, my process is as follows:
1. Open Mechanical.
2. Import the geometry file.
3. Then run the script, which uses dyna = Model.AddLSDynaAnalysis(), but this way I am unable to solve the problem.
Unless I follow these steps:
1. Open Workbench.
2. Open LSDYNA.
3. Import the geometry model.
4. Run the script, which allows for normal solving.
December 18, 2024 at 11:33 am
mohan.urs
Ansys EmployeeHey,
This forum is to discuss workbench LS Dyna and LS Dyna suite. If you need help with pyansys i suggest you look into Ansys Developer Portal | Ansys Developer Portal and forum for the same can be accessed here Home - Community Forum
Also try exploring these examples LS-Dyna analysis — pymechanical-examples and Ball plate — PyDYNA.Regards,
Mohan Urs
5694
1891
1419
