TAGGED: fatal-error, modal-solution, solution-problems, unknown-error
November 22, 2020 at 11:19 am
anamiya
SubscriberIn my modelling I'm unable to get any solution n************************************************************************n The above error is non-recoverable by ANSYS n ANSYS run terminated by the indicated error n Current data base saved if possible. n ******************************************************************nIs there any way to resolve my problem...Thanks in advancenn*** FATAL *** CP = 0.672 TIME= 1***n The requested number of distributed-memory processes (6) exceeds the n number of physical processors that are available (4) on machine: n LAPTOP-LTCEBCQU. The use of virtual processors is not recommended. n It is required that you use a maximum of 4 distributed-memory n processes on this machine. n -
November 22, 2020 at 11:30 am
anamiya
Subscriber*** FATAL *** CP = 0.672 TIME= 16:58:22n The requested number of distributed-memory processes (6) exceeds the n number of physical processors that are available (4) on machine: n LAPTOP-LTCEBCQU. The use of virtual processors is not recommended. n It is required that you use a maximum of 4 distributed-memory n processes on this machine. ndoes this have anything to do with the memory how can it be solved???. -
November 22, 2020 at 5:17 pm
November 23, 2020 at 5:32 am
anamiya
SubscriberThank you very much problem solvednn
- The topic ‘how to resolve unknown error which is non-recoverable by ANSYS ?’ is closed to new replies.
1306
