November 1, 2021 at 2:01 am
Jaeha
SubscriberHi I'm new to ansys, I make a rotating pipe animation using a particle to follow the water flow, can I resize the particle dia meter? If can How?
November 1, 2021 at 1:32 pmKarthik Remella
AdministratorHello,
Are you using 'Pathlines' to visualize the flow (no DPM)? Or is this a DPM simulation? If it is a DPM simulation, you should be able to directly change this under 'Injections'.
If I did not understand your question properly, please share some screenshots.
Karthik
Viewing 1 reply thread- The topic ‘How to resize the particle diameter’ is closed to new replies.
5669
1890
1419
1304
