Ansys Gateway powered by AWS
Ansys Gateway powered by AWS is the solution for developers, designers, and engineers who want to manage their complete Ansys Simulation & CAD/CAE developments in the cloud.
How to renew the Self-Signed certificate for the AD Connector for Ansys Gateway
    • Francis Poussin
      In case you use a self-signed certificate for the Gateway Connector, you may experience the certificate to expire after 1 year.
      This will cause the Gateway agent to no more be able to interface with the Active Directory and will prevent operations on Ansys Gateway powered by AWS.
      In order o renew the Self-Signed certificate, you need to follow the following steps:
      1. Stop and delete existing Ansys.Gateway.AdConnector service
        1. To delete it run this in Windows command prompt “sc delete Ansys.Gateway.AdConnector”
      1. Run these 2 commands in PowerShell with Admin permissions
        1. New-SelfSignedCertificate -DnsName $myDomain -CertStoreLocation "cert:\LocalMachine\My"
        1. $myDomain should be the actual domain used for the OU which you created
          1. Move-Item -Path "cert:\LocalMachine\My\{thumbprint}" -Destination "cert:\LocalMachine\Root"
        1. {thumbprint} should be the actual thumbprint returned from the first PS command
      1. Run the install.ps1 command with the new thumbprint to reinstall the service.
        1. In a PowerShell window, cd to the ACSAdmin folder and run the install.ps1 command with the followingarguments:
          1. -username "username": username for the account to be used to join users and machines to theOrganizational Unit.
          2. -password "password": password for the domain join user account.
          3. -thumbprint "thumbprint": Specify the thumbprint value that you obtained in the previous step.
            For example:.\install.ps1 -username "domainjoin@company.com" -password "agw123" -thumbprint"b6f70dc3d000791ece744ec67c34eb92cbbe97e0"
Viewing 0 reply threads
