How to remove grid lines in ansys fluent.
    • pauliman
      Hello,nI have been using Ansys to save pressure contours for research I am working on. However, with the newer updates there are grid lines that affect the look of these contours. Is there a way to remove these lines so I can save the images without them? I have not been able to find any documentation explaining how so any help would be greatly appreciated. I included a image that shows the lines I need removed below. nn
    • DrAmine
      Do you mean the background grid? If yes you can switch that off under File/Preferences/Graphicsn
      It's the part under Graphics Effects. Leave anti-aliasing alone, alter the remainder of the section to your personal preference. Note, I have some beta flags set so the panel may differ slightly to yours. nn
    • pauliman
      Hello, nThank you both very much. This answers my question. Have a great day.nn
  • The topic ‘How to remove grid lines in ansys fluent.’ is closed to new replies.
