May 13, 2024 at 7:01 pm
Jianghu
SubscriberI am running a coal combustion case. The residual has spikes every time the discrete phase is simulated.
I kept the momentum for 1st order for momentum for 6700 iterations. But the continuity residual didn’t drop much. Once I changed momentum to 2nd order, the continuity residual jumped.
Is there any suggestion to reduce the continuity residual.
May 13, 2024 at 7:05 pm
May 16, 2024 at 10:19 am
Prashanth
Ansys EmployeeYou must play with the under relaxation factors (DPM URF etc.) with first order scheme first, make it stable and then move to second order schemes.
- The topic ‘How to reduce residual for a coal combustion case’ is closed to new replies.
