February 26, 2022 at 2:27 pm
MatthewB
SubscriberHello Everyone,
I'm trying to create simple transient simulation of pumping out air from the box. How can I achive that? What should I define in outlet of the box? Should it be preasure set for 0? Is it any way to determine preasue inside of box at the start of simulation?
February 28, 2022 at 5:07 pmRob
Forum ModeratorI assume you're running transient? What is the gas density set at?
March 9, 2022 at 9:00 amMatthewB
SubscriberHi Rob,
Yes, I'm doing transient simulation.
Gas density - I took air from library, density constant = 1.225
Best Regards Mateusz
Viewing 2 reply threads- The topic ‘How to pump out(create vacuum) air from box?’ is closed to new replies.
5824
