November 1, 2019 at 5:44 am
bidhek
SubscriberActually, I am trying to learn time history analysis in Workbench for a nonlinear structure, while applying acceleration in full transient analysis for nonlinear analyses, I am not being able to set boundary conditions while selecting base excitation for application of acceleration time history. Can I get any suggestions or procedures for performing time history analysis for a nonlinear reinforced concrete structure?
November 1, 2019 at 10:09 am
peteroznewman
SubscriberYou have two choices.
1. Use Fixed Supports on the base and apply an Acceleration load. This will act on the mass of the structure. All the displacements in the solution will be relative displacements to the base. This is your best choice.
2. Use matlab or other program to perform numerical integration on the acceleration-time history to compute the displacement-time history. Use that in a Displacement boundary condition. All the displacements in the solution will be absolute. In order to see the relative displacement of the tip of the model, you have to subtract off the base displacement. This is a pain. If you only care about stress or strain, then you get that without any extra effort.
November 2, 2019 at 4:03 pm
bidhek
SubscriberThank you so much Mr.Peter. I will try your suggestions. I may need more suggestions further, so I will not close this discussion.
thank you..
November 5, 2019 at 9:58 am
November 5, 2019 at 1:50 pm
peteroznewman
SubscriberSet Base Acceleration to No to use the Acceleration load.
November 5, 2019 at 4:57 pm
bidhek
Subscriberactually, I need to apply the base acceleration for seismic analysis of the shear wall to check the time history at different location of the shear wall. Is there any other way to apply base acceleration for full transient analysis for nonlinear time histories analysis in workbench without the linking transient with modal analysis?
November 6, 2019 at 12:52 am
peteroznewman
SubscriberIn a Transient Structural, with no Modal, you can apply Displacements to the base supports.
November 6, 2019 at 12:55 am
bidhek
Subscriberthank you Mr peter, I will try your suggestion.
April 30, 2020 at 5:27 am
mustafas
SubscriberHi Mr.Peter,
For Non-Linear Transient Analysis, if the base excitation is selected YES, boundary conditions can not be selected, a yellow highlight is present. If selected NO, then All Bodies is the only selection.
Hence I am kindly asking how to perform Non Linear Transient Analysis by applying acceleration to a boundary condition ?
Thanks,
May 4, 2023 at 12:24 am
Randel Ilumin
SubscriberHello. I would like to ask how about the weight or effect of gravity load? Is it right to add +9.81 to the vertical acceleration component?
- The topic ‘How to perform nonlinear time history analyses for a Reinforced Concrete structure?’ is closed to new replies.
6014
