February 6, 2024 at 6:55 am
Rex LIOU
Subscriber -
February 6, 2024 at 11:19 am
Aniket Chavan
Forum Moderator -
February 10, 2024 at 12:24 am
Reno Genest
Ansys EmployeeHello Rex,
Could you give us more details and show an image of your rotating object? What is making the object rotate? For example, if you have a ball attached to a string going in a circle, the centrifugal force would be equal to the tension in the string.
Reno.
February 18, 2024 at 3:08 am
Rex LIOU
SubscriberI set an axial constraint on the top of the red object and rotate it clockwise at high speed. I want to know the centrifugal force of the red object.
February 16, 2024 at 2:29 am
February 20, 2024 at 10:53 pm
Reno Genest
Do you have a contact between the red and blue parts? If so, you could post-process the contact force in the normal direction between the 2 bodies to get what you want.
Reno.
Viewing 4 reply threads
- The topic ‘How to output or measure the centrifugal force of a rotating object in LS DYNA?’ is closed to new replies.
