December 29, 2020 at 4:05 am
AfsoonNejati
SubscriberI have a problem using ANSYS LS-DYNA. I have installed the ANSYS software through CMC with the license: Ansys Campus Solutions (Research). Later, since I needed to work with LS-DYNA, I found that the student version has this for free. I have installed the Ansys 2020R2 LS-DYNA Student. However, I cannot open LS-DYNA. Image1 shows the options I see through the start menu.
December 29, 2020 at 4:47 ampeteroznewman
SubscriberArray
The Start Menu for Ansys 2020R2 LS-DYNA Student has an item called LS-Run. That is what I used to run a .k file. Once it ran, I was able to open LS-PrePost to look at the results.
I didn't use the LS-DYNA Powershell at all.
December 29, 2020 at 3:12 pmAfsoonNejati
Subscriber@peteroznewmanÂ
Thank you so much for your reply. Yes! that worked. However, still, I don't have any access to the LS-DYNA Program Manager ...
Kind regards,
January 23, 2021 at 10:05 pmNadeem_ahmed
SubscriberAugust 5, 2021 at 8:28 amuser deleted
Subscriber.Can anyone help with solving this problem?
.Viewing 4 reply threads- The topic ‘How to open LS-DYNA?’ is closed to new replies.
3862
1414
1220
1118
1015
