March 21, 2020 at 6:33 am
Chinmay
SubscriberI am currently doing a project where I insert a zinc body in a copper casing while deforming it. There is frictional contact between them, I gave displacement as Input, I got the animation where it deforms the copper casing but I wish to obtain how much force is required to push zinc body inside copper casing in terms of graph. I tried "Force Convergence:" in output but it's not giving me required results. Can anyone please help ? Following is the animation which I obtained.
https://drive.google.com/file/d/1YD0iZLURCmnNiWXShla7ognoaHYmEtxs/view?usp=sharing
- CK
March 21, 2020 at 11:47 am
peteroznewman
SubscriberRight click on the Solution branch. Insert a Probe > Reaction Force > select the Displacement boundary condition. That will create a graph of the Insertion Force vs Time. If the insertion distance is 5 mm, you can make the End Time 5 seconds, then the graph can be interpreted to be Force vs Displacement.
April 29, 2020 at 6:19 am
Chinmay
SubscriberThank you Sir for your reply. This solved my query.
- The topic ‘How to obtain ‘Force value’ as ‘output’ ?’ is closed to new replies.
6254
