How to obtain element connectivity matrix?
    • mirhan
      Hi to all,
      I would like to obtain information of element connectivity matrix. Like in the figure block 1 and 3, 1 and 2 are connected to each other. What is the way of learning this info from ansys. Also, is there a chance to obtain shared nodes of these blocks?
      Thank you.
    • 1shan
      nThe HBMAT command has an option to write a mapping file between the matrix equations and the corresponding node numbers and degrees of freedom. Have you checked it out?nRegards,nIshan.n
  • The topic ‘How to obtain element connectivity matrix?’ is closed to new replies.
