September 1, 2021 at 3:00 pm
memo
SubscriberHi,
I want to change the maximum and minimum values of the stress contour plots in ANSYS Mechanical. In old versions we could do this by simply selecting the maximum and minimum values and entering numbers that were greater than their values (without considering their signs). However, in 2021 version I am not able to do this. Previously we could also load multiple results in CFD Post to compare them or presenting results in various forms. However, in the 2021 version this is not also possible. Are we supposed to use a different software like TECPLOT to see ANSYS results? This doesn't seem normal at all!
September 2, 2021 at 1:21 pmmemo
Thanks for your help.
But this is not working for all cases.
Regards Memo
Viewing 1 reply thread- The topic ‘How to modify the maximum and minimum values of contours in ANSYS Mechanical’ is closed to new replies.
6485
