February 14, 2021 at 10:01 am
Wazawaki
SubscriberHi,
I'm new to Ansys and I've designed a red blood cell using soldiworks and now I'm trying to mesh it. However, when I mesh it, the thickness (0.2 microns) of the structure doesn't seem to be correct. I'm using shell elements too Any ideas on how I can go about solving this problem? Thank you
February 15, 2021 at 4:28 pmGovindan Nagappan
Ansys Employee@Wazawaki nTurn off the thickness display and see the actual mesh on the surface. See if it follows the geometrynn
nn
February 16, 2021 at 9:07 amFebruary 16, 2021 at 2:21 pmGovindan Nagappan
Ansys EmployeenI assume the lines are the geometry edges. Why are the edges away from the face? This might be a problem with the geometry. See if you can split the surfaces in solidworks and then try to mesh it againnViewing 3 reply threads- The topic ‘How to mesh curved structures’ is closed to new replies.
6730
1314
1032
