Preprocessing
Preprocessing
How to mesh a perforated cylinder?
    • shivam321998
      I would like to generate a mesh on this body with minimum orthogonal quality more than .15 It's dia of 23mm and 2mm for the cylinder and holes respectively with cylinder height of 200mm. Is it possible to do a structured mesh ?
      What type of simulation do you want to do: CFD or Structural?
    • shivam321998
      CFD
      Do you need to include the holes, or are you just wanting to see the pressure loss?  Read up on porous media, and specifically porous jump.
    • shivam321998
      I need the holes since I want the flow characteristics too. It's a part of the model where it's acting as a fin. I've tried porous media on a hollow cylinder but the results didn't match with the experimental model
      You just want a porous jump for the tube surface, or a porous media if the tube has a physical size.
      I wouldn't try and get a structured mesh on this: it'll take ages and hasn't been necessary in about 15 years! You will need a fine mesh to pick up the holes and any jetting so some domain decomposition will be necessary.
    • shivam321998
      Alright, I'll go ahead with porous media and tweak with it. Thank You
Viewing 6 reply threads
  • The topic ‘How to mesh a perforated cylinder?’ is closed to new replies.
