October 8, 2021 at 10:34 am
enginkuser
SubscriberHi,
I inserted a .cdb shell mesh file to Workbench via "External Model" block and I'd like to open KEYOPT,1,5 option on this shell model. How can I do it in ANYSY mechanical?
October 8, 2021 at 1:14 pmGovindan Nagappan
Ansys EmployeeIn Mechanical, right click on the shell under geometry and insert command. Type the command you want to use
Check help doc for proper command usage - KEYOPT (ansys.com)
You may have to use : keyopt,matid,1,5 ! where 1 is keyoption number and 5 is the value. Change it as needed for the element. Check the element reference guide for details of keyoption for specific element
Viewing 1 reply thread- The topic ‘How to insert KEYOPT,1,5 option on Worbench?’ is closed to new replies.
5844
