September 5, 2022 at 3:38 am
mostafa.geriesh
SubscriberI am solving a transient analysis of an impact that involves multiple materials including concrete and stainless-steel. After defining the material damping ratio in the engineering data for stainless-steel, ANSYS gives me the following info:
"Material constant damping ratio defined in Engineering Data is not contributing to modal damping calculation."
What should I do to include material damping ratio in the solution?
September 5, 2022 at 3:50 am
Charudatta Bandgar
SubscriberHello Mostafa Geriesh
If you are using Ansys mechanical for this, this will not be the right forum for you. This ANSYS Discovery Community Forum is intended for seeking help on ANSYS Discovery products. Please post it on ANSYS Customer Portal or Ansys Learning Forum based on the type of license that you have. Thank you for your understanding!Â
- The topic ‘How to include material damping ratio of engineering data’ is closed to new replies.
6760
1330
1097
