September 22, 2023 at 12:51 pm
Anthony Bowers
SubscriberHi all,
How can I impose a pressure drop or mass flowrate for my following fluid domain? Would I use a profile UDF?Â
I am trying to simulate a representative elementary unit of a packing element.
A gas will flow upward by induced flow rate or pressure drop. The faces on the top, bottom, right, and left are periodic while the front and back are wall conditions.Â
-ThanksÂ
September 22, 2023 at 2:53 pm
Forum ModeratorI don't think you can use periodic as there aren't one pair of "ends" to the section. Similarly periodic & symmetry doesn't look practical. You may need to model a slightly larger section and use symmetry planes to the sides.Â
Gas going up, are you planning on liquid going down?Â
September 22, 2023 at 2:55 pm
Anthony Bowers
SubscriberMany sources use this method in ansys for REU. No single phase. Is a pressure drop implementation just a source term?Â
September 22, 2023 at 3:04 pm
Forum ModeratorPressure drop would be boundary conditions. You can use porous media or source terms on the cell zones, but I don't think that's what you want here.Â
September 22, 2023 at 3:06 pm
Anthony Bowers
SubscriberCFD-based study on structured packing geometry - ScienceDirect
This was done in ANSYS with 4 periodic boundary conditions and a pressure gradient applied in the z -direction.Â
- The topic ‘How to impose a mass flowrate or pressure drop without boundaires’ is closed to new replies.
