November 22, 2024 at 3:22 pmHuiboSubscriber
Dear,
I created a hex domain mesh in Ansys Meshing, but the orthogonal quality wasn't very good. The minimun of it was 1.7194e-010. My geomertry is very complex, it is used for heat transfer.
Could you please give me any suggestion on Ansys Meshing to imporve it?
Thank you so much in advance.
November 22, 2024 at 3:44 pmDeepakAnsys Employee
Feature Suppress allows you to remove small features that may create a bad-quality mesh. By suppressing these small features, you can potentially improve the mesh quality. You can preview the faces to be suppressed using the Show > Suppressible Feature option before suppressing them. (2. Feature Suppress)
Please refer to these courses in Ansys Mechanical Meshing,
Topics in Meshing for Structural Analysis | Ansys Courses
Advanced Topics in Ansys Mechanical Meshing | Ansys Courses
Thanks,
Deepak
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Warning Plugin Error Geometry in Design Modeler
- SpaceClaim stops sharing topology
1406
599
591
555
366
