August 24, 2024 at 7:27 pm
August 26, 2024 at 7:11 am
NickFL
SubscriberThose are not different bodies (notice you only have 1 Part, 1 Body in the tree). These lines are showing changes in the tangency or something similar. You should might be able to combine these three faces into one by using the Tools (from the pull-down menu) -> Merge -> Faces.
If you are annoyed by these line due to the mesher resolving these lines, you could try Virtual Topology in the Meshing application.Â
