TAGGED: bonded-contact, contacts, geometric-penetration, mesh, shared-topology
September 3, 2020 at 3:35 am
ehsan120
SubscriberHi,nnI have several parts that they are connected with bonded contacts (I cannot use the sharedtoplogy since it will make so many difficulties for making a good quality mesh). All these parts has initial states (strain or stress). The problem is that when I introduce these initial states, bonded contacts are not recognized by the solver and parts start showing the penetrations. I removed the initial stats and thing are working properly. Is there any specific setting for the contact in this problem that I can change and solve this issue?!nIs there any better way than bonded contact to tie parts in ansys?.Thanksn -
September 3, 2020 at 1:59 pm
Ashish Khemka
Forum ModeratornnCan you share the initial contact status using Contact Tool?.Regards,nAshish Khemkan -
September 3, 2020 at 3:32 pm
ehsan120
SubscribernnThanks for the response. I am a newbie in Ansys so those setting are mostly default settings. Attached you can find a simple example of what I am trying to do. I really appreciate you help in advance.Thanksnn
- The topic ‘How to have bonded contacts and initials state at the same time’ is closed to new replies.
1312
