July 23, 2021 at 8:11 pm
sekhariitkgp
SubscriberDear all,
I am simulating a three phase slurry system using mixture model. In my system I have 8 solids phases with different particle diameter, one bitumen liquid phase and carrier fluid. Particle diameter ranging from 75 micron to 1000 microns. Now I wan to combine all the solid phase into a single solid phase through any UDF function to avoid number of phases. Any leads on this matter, please comment or respond to this.
Best regards
Sekhar
July 26, 2021 at 11:14 amRob
Forum ModeratorYou don't use a UDF you alter the mixture model such that you only have one granular phase. Or model the slurry as a nonNewtonian liquid and don't worry about the solids: you need to understand the flow and physics to use this approach.
July 31, 2021 at 7:52 amsekhariitkgp
SubscriberThank you Rob for your clarification. I found that granular flow model (KTGF) will work for single size particle if it considered as phase. If that is case, we can't group different solids into a single solids. Once should have to create number of phases baaed particle diameter
Viewing 2 reply threads- The topic ‘How to group different solids in a slurry system into single solid’ is closed to new replies.
4858
1587
1386
1242
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
