March 16, 2019 at 11:56 am
deepmech.maurya
SubscriberHello sir
1) during analyses in > analyses setting > output controls> nodal forces -yes was opted by me.
But in result analyses i am not getting forces at node option.
please specify the step to get the nodal forces.
March 20, 2019 at 3:26 am
Sandeep Medikonda
Ansys EmployeeMake sure you are using the supported analysis type and also check out the notes in the help document.
How to access ANSYS online help
March 21, 2019 at 8:05 am
deepmech.maurya
SubscriberHello sandeep sir,
I am IIT kanpur student we have academic license, in that case can we get special help(means other than student community)
March 21, 2019 at 1:08 pm
Sandeep Medikonda
Ansys EmployeeHi Maurya,
You can escalate this post via your account manager if you don't get enough help here.
But first, I would request you to please try and explain what you are trying to do using inline pictures? Explain your model and show the exact error.
Sandeep -
March 22, 2019 at 5:09 am
deepmech.maurya
How to get the Forces at specified node no?
I am performing crack analyses and have to verify the result by calculation.
Here is a picture of specified portion of analyses, i want the forces on all of these nodes.
i know the node no's i.e. 45, 161,162, ...
during analyses in. analyses setting > output controls> nodal forces -yes
i on the output control for nodal forces.
Now How to get the nodal forces at specified nodes, i tried the worksheet method please elaborate the process with some example.
In last answer you mention Ansys help that is for customer who have working license.
I am also interested in learning APDL commands, Can you tell me any authorised centre near Kanpur for APDL training.
March 27, 2019 at 9:12 pm
David Weed
You can make a named selection for each node and in a command object, use cmsel and issue FSUM to get the nodal forces.
March 29, 2019 at 5:03 am
Sandeep Medikonda
Ansys EmployeeAll students should have access to the online manual in v19 or later. There is a small workaround on how to access it:
I've already posted this link above. Please take a moment to read through it.
September 15, 2020 at 5:36 am
ThomasDD
SubscriberWhat is the ACT equivalent to the APDL FSUM command?n
- The topic ‘how to get the nodal forces?’ is closed to new replies.
5844
