July 2, 2020 at 9:54 am
PSiedlac123
SubscriberHi,
Is any way to get list of "Recently used files" from ACT or in Workbench scripting console, besides manually digging in %appdata%ANSYSvXXXFileManagement.XML ?
What is my reason: Simple. My projects are located in deep path which is not shown in detail inside Workbench GUI>Files, but it is crucial for me to know what path these files are located. My paths are names of general projects, and files names have details on contents.
EDIT...:
my paths are e.g.
\Project_2020\EFA\OPT\1_solve\EFA1_rod_optimisation_PDM20200322_R19.wbpj
So i made not an solution myself as follows.
## based on https://stackoverflow.com/questions/15086674/ironpython-xml-reader-in-net-2-0 probably HFSS
## sys.version '2.7.4 (IronPython 2.7.4 (2.7.0.40) on .NET 4.0.30319.42000 (64-bit))'
import xml.etree.ElementTree as ET
PATH_IN = "C:\Users\zws\AppData\RoamingAnsys\v190\UserRegFiles_2027930923\FileManagement.XML"
tree = ET.parse(PATH_IN)
root = tree.getroot()
if 1==2:
print tree._root.tag
print tree._root._children[0].tag
print tree._root._children[0].keys() #
print tree._root._children[0]._children[0]._children[0]._children[0].tag #
print tree._root._children[0]._children[0]._children[0]._children[0]._children[0].keys() #
print tree._root._children[0]._children[0]._children[0]._children[0]._children[0].get('Value')
vlst_ = tree._root._children[0]._children[0]._children[0]._children[0]._children[0].get('Value')
for i in zip(range(100),):
print i
July 8, 2020 at 9:24 am
PSiedlac123
Subscriberbtw. FileManagement.XML collects paths for all open files in classes of GeometryFileType, Projects, LegacyMechanicalFileType, EngineeringData, and Journal.
I was surprised that execution of above code reruned ~70 project entries
That is more than hard coded 20 ! The last 20 is visible in Workbench File menu.
July 9, 2020 at 12:20 pm
Karthik Remella
AdministratorExcellent! It seems like your issue is resolved. If this is the case, could you please mark your update as 'Is Solution'. If you are still looking for an answer, please let us know here and we will be happy to help.
Thank you.
Karthik
- The topic ‘How to get “Recently used files” from ACT in Workbench’ is closed to new replies.
6625
1311
