September 28, 2024 at 2:33 pm
zhengqi
SubscriberHi, I am using Lumerical Interconnect. I have successfully run the simulation. I want to collect the results in the ONA (Optical network Analyzer) using Luemrical Scripting Language (lsf). How can I do it?Â
I tried 'getdata' command, but it seems I cannot get it worked properly. Specifically, I am using A = getdata('ONA_1', 'input 1/mode 1/transmisison'), and then I see A contains three fields, 'TE transmission', 'wavelength', and 'frequency'. But I just cannot futher access the values of the 'TE transmission'. My overall goal is to use LSF to retreive the simulated frequency points and the corresponding frequency responses, and then save them to a text file, instead of by clicking in the GUI.
ThanksÂ
October 2, 2024 at 9:33 am
Niki Papachristou
Forum ModeratorHi Zhengqi,
Thank you for reaching out to us! Correct me if I am wronf but it sounds like you want to isolate one dimension out of your results matrix, hence may I ask you whether you are aware about pinch - Script command?
Let me know if that was helpful or you need further assistance.
Kind Regards,
Niki
