May 31, 2018 at 1:22 pm
h395523899
SubscriberHow to get a certain face through the curve of flow rate versus time.
What I know is to get relevant data on this surface by creating a surface report.
However, I did not find out how to show the relationship between the volume m3 flowing over the surface and the time t.
I only found that the flow m3 of the entire model can be set to change with time t in the volume report.
May 31, 2018 at 1:24 pm
June 8, 2018 at 9:17 am
Keyur Kanade
Ansys EmployeeHello h395523899,Â
You can use Solving --> Reports --> Defintions --> New --> Surface Report --> Volume flow rate as shown in attached image.Â
You can change the Frequency as per your requirement.Â
Keyur
- The topic ‘How to get a certain face through the curve of flow rate versus time.’ is closed to new replies.
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
1494
1386
1209
