March 5, 2026 at 3:25 pm
March 6, 2026 at 6:48 am
bb411004
Subscriber這是21700é›»æ± Â
March 6, 2026 at 7:20 am
NickFL
SubscriberWhat are your boundary conditions? I assume you have a heat source term in the body (battery) that is causing the middle to be warmer.Â
March 7, 2026 at 6:03 am
March 7, 2026 at 6:05 am
March 7, 2026 at 6:07 am
March 9, 2026 at 8:50 am
NickFL
SubscriberYou are using the Battery Pack module in Fluent. I do not have much experience with it, so maybe someone else on here can help you more. But I do have a couple debugging tips I can give.
1) Double check your dimensions. It would not be the first time where the dimensions caused stange results (I speak from experience).
2) What do your back of the envelope calculations say the temperature should be for the given conditions.
3) Double check the units on everything.
4) Is radiation really necessary? Here you have 400°C, but we expect that the temperature should not be so warm. Therefore it may be unnecessary to consider this term.
March 7, 2026 at 6:08 am
bb411004
SubscriberI don't know where the setting is wrong. I've consulted the AI, but it couldn't solve the problem either. I would appreciate any further assistance from the expert. Thank you.
6044
.png)
