July 6, 2021 at 3:40 pm
LCP
SubscriberHello,
I am modelling a hyperelastic, incompressible 2D valve (essentially just a simple rectangle). I want it to bend, and make sure this happens by applying a pressure to the side of the rectangle.
I am using a shell element with option 13, which equals 2D solid element with plane strain assumption.
When I compare the results for NIP = 1 (1-point Gauss integration) and NIP = 4 (2x2 Gauss integration), I find that the bending in the simulation for NIP=4 is much smaller than for NIP=1. I suspect that this is due to shear locking for the fully integrated elements.
How can I fix this issue?
Kind regards,
July 13, 2021 at 2:16 pmRam Gopisetti
Ansys EmployeeDo check the following Link for further understanding the Element locking
Cheers, Ram
July 14, 2021 at 10:25 pmJim Day
Ansys EmployeeIf there is only one element through the thickness, the case with NIP=1 will have only one integration point through the thickness and thus will lack bending stiffness.
Viewing 2 reply threads- The topic ‘How to fix shear locking in LS-DYNA?’ is closed to new replies.
4007
1461
1287
1124
