Ansys Free Student Software
How to fix: ANSYS LICENSE MANAGER ERROR: Not enough ANSYS Neutral Parallel licenses 5/4
    • Luca_Patriarchi
      Hi all,
      I have troubles with Ansys Mechanycal R2 2020 student edition. When I try to run, this message occures:
       ANSYS Mechanical Enterprise
       *** IMPORTANT LICENSING MESSAGE ***
       Not enough ANSYS Neutral Parallel licenses 5/4.
       *** ERROR - Insufficient HPC licenses available.
      whybad=      -1071
      +--------- D I S T R I B U T E D  A N S Y S  S T A T I S T I C S ------------+
      Release: 2020 R2           Build: 20.2      Update: UP20200601  Platform: WINDOWS x64
      Date Run: 04/28/2022  Time: 18:20    Process ID: 24252
      Operating System: Windows 10 (Build: 22000)
      Processor Model: Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz
      Compiler: Intel(R) FORTRAN Compiler Version 19.0.0 (Build: 20190206)
               Intel(R) C/C++ Compiler Version 19.0.0 (Build: 20190206)
               Intel(R) Math Kernel Library Version 2020.0.0 Product Build 20191125
      Number of machines requested           :   1
      Total number of cores available        :   8
      Number of physical cores available     :   4
      Number of processes requested          :   4
      Number of threads per process requested :   1
      Total number of cores requested        :   4 (Distributed Memory Parallel)
      MPI Type: INTELMPI
      MPI Version: Intel(R) MPI Library 2018 Update 3 for Windows* OS
      Number of GPUs requested               :   1
      GPU Acceleration: NVIDIA Library Requested but not Enabled
      GPU Device with ID = 0 is: GeForce MX350
      GPU Driver Version: 11.20
      CUDA Version: 10.0
      Job Name: file0
       Core               Machine Name  Working Directory
          0            LAPTOP-P60EEL51  D:ProgrammiANSYS IncAnsys Projects\_ProjectScratchScr5454
          1            LAPTOP-P60EEL51  D:ProgrammiANSYS IncAnsys Projects\_ProjectScratchScr5454
          2            LAPTOP-P60EEL51  D:ProgrammiANSYS IncAnsys Projects\_ProjectScratchScr5454
          3            LAPTOP-P60EEL51  D:ProgrammiANSYS IncAnsys Projects\_ProjectScratchScr5454
      Total CPU time for main thread                   :       0.4 seconds
      Total CPU time summed for all threads            :       0.1 seconds
      Elapsed time spent obtaining a license           :       1.5 seconds
      Elapsed time spent pre-processing model (/PREP7) :       0.0 seconds
      Elapsed time spent solution - preprocessing      :       0.0 seconds
      Elapsed time spent computing solution            :       0.0 seconds
      Elapsed time spent solution - postprocessing     :       0.0 seconds
      Elapsed time spent post-processing model (/POST1) :       0.0 seconds
      Maximum total memory used                        :       8.0 MB
      Maximum total memory allocated                   :       0.0 MB
      Total physical memory available                  :        16 GB
      Total amount of I/O written to disk              :       0.0 GB
      Total amount of I/O read from disk               :       0.0 GB
      +------ E N D  D I S T R I B U T E D  A N S Y S  S T A T I S T I C S -------
       |                      DISTRIBUTED ANSYS RUN COMPLETED                    |
       | Ansys 2020 R2              Build 20.2        UP20200601    WINDOWS x64 |
       | Database Requested(-db) 1024 MB   Scratch Memory Requested        0 MB |
       | Maximum Database Used      1 MB   Maximum Scratch Memory Used     1 MB |
       |       CP Time     (sec) =         0.141      Time = 18:20:56       |
       |       Elapsed Time (sec) =         4.000      Date = 04/28/2022     |
      How can I fix it?
    • George Karnos
      I see that you are selecting to use a GPU.
      Choose None for GPU as that would need an extra hpc license and Free student is limited to 4.
  • The topic ‘How to fix: ANSYS LICENSE MANAGER ERROR: Not enough ANSYS Neutral Parallel licenses 5/4’ is closed to new replies.
