November 23, 2022 at 2:38 am
Thomas Rodriguez
I am trying to run a script that builds a transistor and assigns an excitation to one of the faces of a box (there are a few boxes that need an excitation, but I want to get one working before I add the others). However, whenever I try to run the code, I get an error that that FaceID is incorrect. When I try to look up the FaceID of all the objects, the numbers are getting bigger each time I run the code. So the code has to change each time, which confuses me.
I delete all the objects on the HFSS model before I run the script everytime so that I can see my device being built each time. What should I do fix this issue? This is a big bottleneck for my work.
January 27, 2023 at 6:04 pm
gbonomo
SubscriberI am also very interested in this topic, have you found any solution?
April 25, 2023 at 7:48 am
Praneeth
Ansys EmployeeHi Thomas,
Thank you for reaching out to the Ansys learning forum and your patience is much appreciated.
If you are interested to select a particular face, then you can use "select face by plane" instead of face id. Please go through "selecting faces by plane" section of the HFSS help document for detailed information. Alternatively, you can go through this online help link - Ansys Electronics 2023 R1 - Selecting Faces by Plane.
Best regards,
Praneeth.
- The topic ‘How to find the face number on HFSS model’ is closed to new replies.
1306
