May 19, 2022 at 12:49 pm
FirasBejar
SubscriberHello,
I have a simple geometry let's say a cube to which a force is being applied. I want to extract the strain energy density but I can only find the strain energy under solution. How can I do so?
Is there a direct relation between the strain energy and the strain energy density?
And I believe the strain energy is a field that changes throughout the structure, can I average it to a single value by summing up all the local values and dividing by their number? Does this even have a physical meaning?
Many thanks,
May 20, 2022 at 7:47 amAniket Chavan
Forum ModeratorEnergy density = Energy / Volume.
This can be done in Workbench Mechanical using User Defined Results.
1. Under the Solution tree, insert a "User Defined Result"
2. In the Details of the "User Defined Results", and under Expression, enter "ENERGYPOTENTIAL/VOLUME"
-Aniket
Viewing 1 reply thread- The topic ‘How to extract the strain energy density data in Ansys?’ is closed to new replies.
