how to export the Solver Output to txt using Scripting?
    • Gary Wang
      Hi I am using workbench scripting for post processing. After solving, I want to save all the contents in the Solution/Solution Information/Solver Output to .txt using Scripting. I can RMB in the GUI to choose all and copy to .txt. But how can I use Scripting under Automation to realize this?
      Thanks a lot.
    • Nanda
      Hello Gary,
      You can copy the solve.out file from solver files directory. Right click on solution--> open solver file directory--> solve.out file.
      Nanda.
    • Gary Wang
      Hi Nanda,
      Thanks for your reply. I am using Scripting to run several cases, and I want to save the solve.out file for each of them. So I am asking to use scripting or APDL method to finish the task. I can't manually copy or save everytime. Can I do it automatically?
      Thanks
  • The topic ‘how to export the Solver Output to txt using Scripting?’ is closed to new replies.
