Preprocessing
Preprocessing
How to export technical drawing from Spaceclaim to PDF
    • bondhanansys
      Hello, Sir.
      I use Spaceclaim 2021R1, everything is good performance. I already finished my technical draw with Spaceclaim. The I try to export to PDF and image by choosing "Save as" but the only one choice is *sdoc* file type.
      Would you tell me how to export the technical draw to pdf and image from Spaceclaim?
    • Keyur Kanade
      It may not be available for student version. You may take print screen. nPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
    • bondhanansys
      Thank you, Sir.n
  • The topic ‘How to export technical drawing from Spaceclaim to PDF’ is closed to new replies.
