How to evaluate the stress component normal to a curved edge
    • Philipp Holzmann
      ist there any way to evaluate the stress component normal to a curved imprinted edge or path without defining local cylindrical coordinate systems for each radius of the imprinted edges?
    • Sahil Sura
      You can get the stress component normal to the surface by always creating the local co-ordinate system and setting one of the axes normal to the given surface. This is the most preferred and easy way. Even the local co-ordinate systems can be generated using object generator.
      The following are the links for the discussions on the same line-
      How I get directional principal stress in Workbench ÔÇö Ansys Learning Forum
      Stress component perpendicular to a surface ÔÇö Ansys Learning Forum
      Vector Principals (ansys.com)
      Since, you want a method other than the local coordinate system method You might want to try the method in which strain is analyzed using a strain gauge (Single element meshed surface with zero stiffness and minimal thickness created at the locations of interest.)Instead of asking strain as output, you can ask stress in the particular direction as the output.
      The following steps might guide you for the same-
      Create a surface at desired locations and update the geometry.
      Define the element types and stiffness by inserting commands (et, matid , 181 and keyopt , matid ,1 ,2 )
      Defining the appropriate contacts.
      Meshing the surface such that it has only one element.
      Adding element triads to the solution output to get respective axes to scope the result for.
      Adding the respective stress and scoping the result to the the solution co ordinate system and axis along with respective geometry.
      Request normal strain from strain gauges on irregular curved surface ÔÇö Ansys Learning Forum
      Elemental Coordinate Systems Results (ansys.com)
      Introduction to the Use of Results (ansys.com)
      Hope that helps.
      Thanks Sahil
  • The topic ‘How to evaluate the stress component normal to a curved edge’ is closed to new replies.
