November 15, 2020 at 11:40 am
ahmed.desoki
SubscriberDear folks
I want to model a bolted connection. There is a clearance between the hole of upper jointed part and the bolt. Hence, the bolt is expected to carry axial load (tension/compression).
The Ansys Beam connection is supposed to model bolts, but unfortunately, such beam connection carries shear and torsion in addition to the axial load.
November 16, 2020 at 1:38 ampeteroznewman
SubscribernInsert a Probe into the results and select the Joint. You will get tabular data on the forces going through the joint and a vector of the total force in the graphics window.nViewing 1 reply thread- The topic ‘How to display the loads carried by a Body-Body joint?’ is closed to new replies.
Innovation SpaceTrending discussions- LPBF Simulation of dissimilar materials in ANSYS mechanical (Thermal Transient)
- BackGround Color
- Contact stiffness too big
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
- Which equations and in what form are valid for defining excitations?
Top Contributors-
4597
1495
1386
1209
