LS Dyna
LS Dyna
How to disable automatic *CONTROL_BULK_VISCOSITY keyword in Workbench LS-DYNA?
    • 2398629771
      Hi everyone,
      I am running a Finite Element Analysis using ANSYS Workbench (LS-DYNA extension). I’ve encountered an issue where the exported .k file automatically includes the *CONTROL_BULK_VISCOSITY keyword, even though I haven't manually added this card in the outline tree.
      This keyword is significantly affecting my simulation results. When I manually delete it from the .k file and run it via the solver manager, the results align perfectly with my expectations. However, I want to find a permanent way to disable or modify this within the Workbench interface to avoid manual editing every time.
      My questions are:
      Where is the setting located in Workbench to suppress or remove *CONTROL_BULK_VISCOSITY?
      Is there a default setting or a Command Snippet that might be triggering this?
      Any insights would be greatly appreciated. Thanks!
    • Nanda
      Please review this help document: 3.13.1. Modifying Default Solver Settings
      Nanda.
      Introducing Ansys Assistant a 24/7 AI-powered virtual assistant for active Ansys academic customers.
      Have a look at our public help documentation website: Ansys Help
      For more exciting courses and certifications, hit this link: Ansys Innovation Courses | ANSYS Innovation Space
    • Dennis Chen
      You can disable everything (as shown above) and insert your own set of default database and control cards.  In a lot of ways, it is way easier to control and manage than the workbench Dyna settings.
      I think it is a just out of habit and perhaps beginner habit that everything should be a GUI based button or setting one changes, but over time, it is so much easier to just use direct inputs in text format.
