How to determine head loss in Ansys?
    • Ezzad
      I am analyzing a 2D flow in a gradual contraction pipe. I am not sure if ansys can directly determine the head loss of the flow simulated.
    • Karthik Remella
      Administrator
      Hello Please look at the following AIC examples and you will have an idea of how to estimate head loss in Fluent.
      You should be able to download the case and data files, and the results PDF should guide you in these calculations.
      Karthik
    • Ezzad
      Hi In the examples you shared, it does not show how head loss is determined.
      Ezzad
      What is head loss? I know but explain below.
    • Ezzad
      Minor head loss or loss of pressure due to pipe fitting in a pipe flow.
      OK, and what would you do to find that in an experiment?
    • Ezzad
      Just find the pressure at the inlet and outlet in Ansys. Then find the pressure difference.
      Correct, so you can use that to get the head loss. There's not a specific function but you can use Custom Field Functions (not as easy as Excel) and Expressions will do the job but won't report back to the solver (you'll need to open & evaluate the expression) if you can't add it to an output parameter.
Viewing 7 reply threads
  • The topic ‘How to determine head loss in Ansys?’ is closed to new replies.
