November 5, 2020 at 8:41 am
frank_koenig
SubscriberHi
We are using a cylinder magnet with diametral magnetization.
November 5, 2020 at 11:09 amNKC
Forum ModeratorHi nIn which tool are you creating this?.RegardsnNavyanNovember 5, 2020 at 2:10 pmfrank_koenig
SubscriberHi,nwe use ANSYS Electromagnetics Suite 17.1.0. formerly known as ANSYS MAXWELL.nRegards,nFranknNovember 6, 2020 at 12:07 amAndyJP
Subscriberwhy not dividing it into 2 objects, magnetized differently?nNovember 6, 2020 at 6:41 amfrank_koenig
SubscriberHi AndyJP,nsorry I can't image your suggestion.nI just know how to set the magnetization direction into x, y or z.nBut how can I add an angle to the any of these directions.nnNovember 8, 2020 at 5:52 amNKC
Forum ModeratorHi,nYou can try defining them as follows.nFor perfect anisotropic separation you can directly create a face coordinate system on the top of cylindrical face and assign magnetization with reference to that.nFor 8 deg. magnetization error, model your magnet as two half cylindrical magnets(with 8 deg deviation) and define face coordinate system for each and assign magnetization with reference to respective coordinate systems.nnRegardsnNavya.nNovember 9, 2020 at 3:52 amAndyJP
Subscriberthe material coercitivity is given in XYZ coordinates. Create two materials with different coercitivity vectors. Apply to different parts of the magnet (separate objects)nViewing 6 reply threads- The topic ‘How to define a (special) magnetization direction’ is closed to new replies.
Innovation SpaceTrending discussions- Three-Phase Voltage Imbalances in dual stator electric generator
- Co-simulation in Q3D, Icepak – meshing problem
- Classic Icepak – clarifications on Boundary condition
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
Top Contributors-
4587
1494
1386
1209
