December 13, 2024 at 9:31 am
332697296
SubscriberI solved the problem to a remote server through ANSYS RSM on Windows, and the job monitor prompted:
unknown option -- -
usage: ssh [-46AaCfGgKkMNnqsTtVvXxYy] [-B bind_interface]
[-b bind_address] [-c cipher_spec] [-D [bind_address:]port]
[-E log_file] [-e escape_char] [-F configfile] [-I pkcs11]
[-i identity_file] [-J [user@]host[:port]] [-L address]
[-l login_name] [-m mac_spec] [-O ctl_cmd] [-o option] [-p port]
[-Q query_option] [-R address] [-S ctl_path] [-W host:port]
[-w local_tun[:remote_tun]] destination [command [argument ...]]Â
ANSYS version: 2024 r1
os:ubuntu 22.04
SSH configuration for password free loginÂ
I calculated normally on the 2020 version
January 3, 2025 at 2:05 pm
MangeshANSYS
Ansys EmployeeHello
please open the RSM job log
right click and select to show debug messages
copy paste test or screen shots of the line which runs solver and also a few lines before and after this error message, redact as necessary before posting publicallyÂ-
January 17, 2025 at 5:56 am
332697296
Subscriber            Ansys Job Report
  Job Name:  luosi-test-DP0---------- (A4)--------------------(A5)------------------ (A6)
  Owner:  OuYang-PC\Administrator
  Submitted:  2025/1/17 13:38:58
  Priority: Â
  Server:  ANSYS-HPC
  Queue:  Debug
  Final Status:  Unknown
  Job Log:  1     |  [2025/1/17 13:38:58]   RSM Version: 24.1.0.0, Build Date: 2023/11/6 16:19:34
  2     |  [2025/1/17 13:38:58]   RSM File Version: 24.1.0.0+Branch.release-24.1.Sha.fb0166b11054371137be5a9146323c18b0567289
  3     |  [2025/1/17 13:38:58]   RSM Library Version: 24.1.0.0
  4     |  [2025/1/17 13:38:58]   Job Name: luosi-test-DP0---------- (A4)--------------------(A5)------------------ (A6)
  5     |  [2025/1/17 13:38:58]     Type: Workbench_ANSYS
  6     |  [2025/1/17 13:38:58]     Client Directory: C:\Users\Administrator\Desktop\_ProjectScratch\ScrD274\
  7     |  [2025/1/17 13:38:58]     Client Machine: OuYang-PC
  8     |  [2025/1/17 13:38:58]     Queue: Debug [ANSYS-HPC, debug]
  9     |  [2025/1/17 13:38:58]     Template: Workbench_ANSYSJob.xml
  10    |  [2025/1/17 13:38:58]   Cluster Configuration: ANSYS-HPC [192.168.5.100]
  11    |  [2025/1/17 13:38:58]     Cluster Type: SLURM
  12    |  [2025/1/17 13:38:58]     Custom Keyword: blank
  13    |  [2025/1/17 13:38:58]     Transfer Option: NativeRsm
  14    |  [2025/1/17 13:38:58]     Staging Directory: /data
  15    |  [2025/1/17 13:38:58]     Delete Staging Directory: False
  16    |  [2025/1/17 13:38:58]     Local Scratch Directory: blank
  17    |  [2025/1/17 13:38:58]     Platform: Linux
  18    |  [2025/1/17 13:38:58]     Cluster Submit Options: blank
  19    |  [2025/1/17 13:38:58]     Normal Inputs: [*.cgns,*.dat,*.mac,*.swf,cp*.*,file*.*,knockdown.ist,thermal.build,SecInput.txt,nlad_mesh_input.msh,nlad_mesh_input.asc,*.comps,*.par,*.rth,commands.xml]
  20    |  [2025/1/17 13:38:58]     Cancel Inputs: [sec.interrupt]
  21    |  [2025/1/17 13:38:58]     Excluded Inputs: [-]
  22    |  [2025/1/17 13:38:58]     Normal Outputs: [*.NR*,*.bswf,*.swf,*.xml,*apip.json,AMHighStrain.txt,AMResults.txt,CAERepOutput.xml,Harmonic*.h5,Harmonic*.vtk,Load_*.inp,Modal*.h5,Modal*.vtk,Mode_mapping_*.txt,NotSupportedElems.dat,ObjectiveHistory.out,PostImage*.png,RemotePostInformation.txt,Static*.h5,Static*.vtk,cyclic_map.json,exit.topo,file*.dsub,file*.ldhi,file*.mntr,file*.png,file*.r0*,file*.r1*,file*.r2*,file*.r3*,file*.r4*,file*.r5*,file*.r6*,file*.r7*,file*.r8*,file*.r9*,file*.rd*,file*.rst,file*.sub,file.BCS,file.DSP,file.PCS,file.ce,file.cm,file.cnd,file.cnm,file.err,file.gst,file.json,file.nd*,file.nlh,file.nr*,file.rdb,file.rfl,file.spm,file0.BCS,file0.PCS,file0.ce,file0.cnd,file0.err,file0.gst,file0.nd*,file0.nlh,file0.nr*,frequencies_*.out,input.x17,intermediate*.topo,knockdown.ist,morphed*.stl,post.out,record.txt,solve*.out,structured_history.xml,topo.err,topo.out,topo_cyclic_map.txt,vars.topo,sec.validation.executed,*.comps,*.par,*.rth]
  23    |  [2025/1/17 13:38:58]     Failure Outputs: [-]
  24    |  [2025/1/17 13:38:58]     Cancel Outputs: [-]
  25    |  [2025/1/17 13:38:58]     Excluded Outputs: [-]
  26    |  [2025/1/17 13:38:58]     Inquire Files:
  27    |  [2025/1/17 13:38:58]      normal: [*.NR*,*.bswf,*.swf,*.xml,*apip.json,AMHighStrain.txt,AMResults.txt,CAERepOutput.xml,Harmonic*.h5,Harmonic*.vtk,Load_*.inp,Modal*.h5,Modal*.vtk,Mode_mapping_*.txt,NotSupportedElems.dat,ObjectiveHistory.out,PostImage*.png,RemotePostInformation.txt,Static*.h5,Static*.vtk,cyclic_map.json,exit.topo,file*.dsub,file*.ldhi,file*.mntr,file*.png,file*.r0*,file*.r1*,file*.r2*,file*.r3*,file*.r4*,file*.r5*,file*.r6*,file*.r7*,file*.r8*,file*.r9*,file*.rd*,file*.rst,file*.sub,file.BCS,file.DSP,file.PCS,file.ce,file.cm,file.cnd,file.cnm,file.err,file.gst,file.json,file.nd*,file.nlh,file.nr*,file.rdb,file.rfl,file.spm,file0.BCS,file0.PCS,file0.ce,file0.cnd,file0.err,file0.gst,file0.nd*,file0.nlh,file0.nr*,frequencies_*.out,input.x17,intermediate*.topo,knockdown.ist,morphed*.stl,post.out,record.txt,solve*.out,structured_history.xml,topo.err,topo.out,topo_cyclic_map.txt,vars.topo,sec.validation.executed,*.comps,*.par,*.rth]
  28    |  [2025/1/17 13:38:58]   Submission in progress...
  29    |  [2025/1/17 13:39:04]   Storage contents:
  30    |  [2025/1/17 13:39:04]     ds.dat
  31    |  [2025/1/17 13:39:04]     remote.dat
  32    |  [2025/1/17 13:39:04]     SecInput.txt
  33    |  [2025/1/17 13:39:07]   Runtime Settings:
  34    |  [2025/1/17 13:39:07]     Job Owner: OuYang-PC\Administrator
  35    |  [2025/1/17 13:39:07]     Submit Time: 2025年1月17日 13:38
  36    |  [2025/1/17 13:39:07]     Directory: /data/bt2fznq7.b31
  37    |  [2025/1/17 13:39:07]   Submission in progress...
  38    |  [2025/1/17 13:39:04]   Submit Host Version: 24.1.0.0, Build Date: 11/6/2023 2:17:32 PM
  39    |  [2025/1/17 13:39:04]   Commands defined in JobDefinition
  40    |  [2025/1/17 13:39:04]   Behavior code: Ansys.Rsm.ClusterOperations.Behaviors.WorkbenchAnsysBehaviors
  41    |  [2025/1/17 13:39:04]   Loading Cluster Customization file /software/ansys_inc/v241/RSM/Config/xml/ClusterJobCustomization.xml.
  42    |  [2025/1/17 13:39:04]   No customization found for cluster machineName master, type SLURM
  43    |  [2025/1/17 13:39:04]   HPC Commands Files Used:
  44    |  [2025/1/17 13:39:04]     hpc_commands_SLURM.xml
  45    |  [2025/1/17 13:39:04]   Environment variables:
  46    |  [2025/1/17 13:39:04]     RSM_PYTHON_HOME=/software/ansys_inc/v241/commonfiles/CPython/3_10/linx64/Release/python
  47    |  [2025/1/17 13:39:04]     RSM_IRON_PYTHON_HOME=/software/ansys_inc/v241/commonfiles/IronPython
  48    |  [2025/1/17 13:39:04]     RSM_PYTHON_EXE=/software/ansys_inc/v241/commonfiles/CPython/3_10/linx64/Release/python/runpython
  49    |  [2025/1/17 13:39:04]     RSM_TASK_WORKING_DIRECTORY=/data/bt2fznq7.b31
  50    |  [2025/1/17 13:39:04]     RSM_USE_SSH_LINUX=False
  51    |  [2025/1/17 13:39:04]     RSM_QUEUE_NAME=debug
  52    |  [2025/1/17 13:39:04]     RSM_CONFIGUREDQUEUE_NAME=Debug
  53    |  [2025/1/17 13:39:04]     RSM_COMPUTE_SERVER_MACHINE_NAME=master
  54    |  [2025/1/17 13:39:04]     RSM_HPC_JOBNAME=Mechanical
  55    |  [2025/1/17 13:39:04]     RSM_HPC_DISPLAYNAME=luosi-test-DP0---------- (A4)--------------------(A5)------------------ (A6)
  56    |  [2025/1/17 13:39:04]     RSM_HPC_CORES=8
  57    |  [2025/1/17 13:39:04]     RSM_HPC_DISTRIBUTED=TRUE
  58    |  [2025/1/17 13:39:04]     RSM_HPC_NODE_EXCLUSIVE=FALSE
  59    |  [2025/1/17 13:39:04]     RSM_HPC_QUEUE=debug
  60    |  [2025/1/17 13:39:04]     RSM_HPC_USER=admin
  61    |  [2025/1/17 13:39:04]     RSM_HPC_WORKDIR=/data/bt2fznq7.b31
  62    |  [2025/1/17 13:39:04]     RSM_HPC_JOBTYPE=Workbench_ANSYS
  63    |  [2025/1/17 13:39:04]     RSM_HPC_ANSYS_LOCAL_INSTALL_DIRECTORY=/software/ansys_inc/v241
  64    |  [2025/1/17 13:39:04]     RSM_HPC_VERSION=241
  65    |  [2025/1/17 13:39:04]     RSM_HPC_STAGING=/data/bt2fznq7.b31
  66    |  [2025/1/17 13:39:04]     RSM_HPC_LOCAL_PLATFORM=Linux
  67    |  [2025/1/17 13:39:04]     RSM_HPC_CLUSTER_TARGET_PLATFORM=Linux
  68    |  [2025/1/17 13:39:04]     RSM_HPC_STDOUTFILE=stdout_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsmout
  69    |  [2025/1/17 13:39:04]     RSM_HPC_STDERRFILE=stderr_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsmout
  70    |  [2025/1/17 13:39:04]     RSM_HPC_STDOUTLIVE=stdout_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.live
  71    |  [2025/1/17 13:39:04]     RSM_HPC_STDERRLIVE=stderr_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.live
  72    |  [2025/1/17 13:39:04]     RSM_HPC_SCRIPTS_DIRECTORY_LOCAL=/software/ansys_inc/v241/RSM/Config/scripts
  73    |  [2025/1/17 13:39:04]     RSM_HPC_SCRIPTS_DIRECTORY=$AWP_ROOT241/RSM/Config/scripts
  74    |  [2025/1/17 13:39:04]     RSM_HPC_SUBMITHOST=192.168.5.100
  75    |  [2025/1/17 13:39:04]     RSM_HPC_STORAGEID=  a15b3179-9ca0-4b8d-8bbf-b71c620eff98  Âyq4vb0am.irl=RsmSocket#ANSYS-HPC$192.168.5.100:0|/data/bt2fznq7.b31  ÂFriday, January 17, 2025 05:38:55.964 AM  ÂTrue
  76    |  [2025/1/17 13:39:04]     RSM_HPC_PLATFORMSTORAGEID=/data/bt2fznq7.b31
  77    |  [2025/1/17 13:39:04]     RSM_HPC_NATIVEOPTIONS=
  78    |  [2025/1/17 13:39:04]     ARC_ROOT=/software/ansys_inc/v241/RSM/Config/scripts/../../ARC
  79    |  [2025/1/17 13:39:04]     RSM_HPC_KEYWORD=SLURM
  80    |  [2025/1/17 13:39:04]   JobType is: Workbench_ANSYS
  81    |  [2025/1/17 13:39:04]   Final command platform: Linux
  82    |  [2025/1/17 13:39:04]   RSM_PYTHON_HOME=/software/ansys_inc/v241/commonfiles/CPython/3_10/linx64/Release/python
  83    |  [2025/1/17 13:39:04]   RSM_HPC_JOBNAME=Mechanical
  84    |  [2025/1/17 13:39:04]   Distributed mode requested: True
  85    |  [2025/1/17 13:39:04]   RSM_HPC_DISTRIBUTED=TRUE
  86    |  [2025/1/17 13:39:04]   Running 1 commands
  87    |  [2025/1/17 13:39:04]   Job working directory: /data/bt2fznq7.b31
  88    |  [2025/1/17 13:39:04]   Number of CPU requested: 8
  89    |  [2025/1/17 13:39:04]   AWP_ROOT241=/software/ansys_inc/v241
  90    |  [2025/1/17 13:39:04]   Checking queue debug exists ...
  91    |  [2025/1/17 13:39:04]   External cluster command: queryQueues ---------------------------------------
  92    |  [2025/1/17 13:39:04]     Cluster command before expansion: sinfo
  93    |  [2025/1/17 13:39:04]     Final cluster command: sinfo
  94    |  [2025/1/17 13:39:04]     Working directory : /data/bt2fznq7.b31
  95    |  [2025/1/17 13:39:04]     Variables:
  96    |  [2025/1/17 13:39:04]       RSM_PYTHON_HOME=/software/ansys_inc/v241/commonfiles/CPython/3_10/linx64/Release/python
  97    |  [2025/1/17 13:39:04]       RSM_IRON_PYTHON_HOME=/software/ansys_inc/v241/commonfiles/IronPython
  98    |  [2025/1/17 13:39:04]       RSM_PYTHON_EXE=/software/ansys_inc/v241/commonfiles/CPython/3_10/linx64/Release/python/runpython
  99    |  [2025/1/17 13:39:04]       RSM_TASK_WORKING_DIRECTORY=/data/bt2fznq7.b31
  100    |  [2025/1/17 13:39:04]       RSM_USE_SSH_LINUX=False
  101    |  [2025/1/17 13:39:04]       RSM_QUEUE_NAME=debug
  102    |  [2025/1/17 13:39:04]       RSM_CONFIGUREDQUEUE_NAME=Debug
  103    |  [2025/1/17 13:39:04]       RSM_COMPUTE_SERVER_MACHINE_NAME=master
  104    |  [2025/1/17 13:39:04]       RSM_HPC_JOBNAME=Mechanical
  105    |  [2025/1/17 13:39:04]       RSM_HPC_DISPLAYNAME=luosi-test-DP0---------- (A4)--------------------(A5)------------------ (A6)
  106    |  [2025/1/17 13:39:04]       RSM_HPC_CORES=8
  107    |  [2025/1/17 13:39:04]       RSM_HPC_DISTRIBUTED=TRUE
  108    |  [2025/1/17 13:39:04]       RSM_HPC_NODE_EXCLUSIVE=FALSE
  109    |  [2025/1/17 13:39:04]       RSM_HPC_QUEUE=debug
  110    |  [2025/1/17 13:39:04]       RSM_HPC_USER=admin
  111    |  [2025/1/17 13:39:04]       RSM_HPC_WORKDIR=/data/bt2fznq7.b31
  112    |  [2025/1/17 13:39:04]       RSM_HPC_JOBTYPE=Workbench_ANSYS
  113    |  [2025/1/17 13:39:04]       RSM_HPC_ANSYS_LOCAL_INSTALL_DIRECTORY=/software/ansys_inc/v241
  114    |  [2025/1/17 13:39:04]       RSM_HPC_VERSION=241
  115    |  [2025/1/17 13:39:04]       RSM_HPC_STAGING=/data/bt2fznq7.b31
  116    |  [2025/1/17 13:39:04]       RSM_HPC_LOCAL_PLATFORM=Linux
  117    |  [2025/1/17 13:39:04]       RSM_HPC_CLUSTER_TARGET_PLATFORM=Linux
  118    |  [2025/1/17 13:39:04]       RSM_HPC_STDOUTFILE=stdout_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsmout
  119    |  [2025/1/17 13:39:04]       RSM_HPC_STDERRFILE=stderr_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsmout
  120    |  [2025/1/17 13:39:04]       RSM_HPC_STDOUTLIVE=stdout_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.live
  121    |  [2025/1/17 13:39:04]       RSM_HPC_STDERRLIVE=stderr_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.live
  122    |  [2025/1/17 13:39:04]       RSM_HPC_SCRIPTS_DIRECTORY_LOCAL=/software/ansys_inc/v241/RSM/Config/scripts
  123    |  [2025/1/17 13:39:04]       RSM_HPC_SCRIPTS_DIRECTORY=$AWP_ROOT241/RSM/Config/scripts
  124    |  [2025/1/17 13:39:04]       RSM_HPC_SUBMITHOST=192.168.5.100
  125    |  [2025/1/17 13:39:04]       RSM_HPC_STORAGEID=  a15b3179-9ca0-4b8d-8bbf-b71c620eff98  Âyq4vb0am.irl=RsmSocket#ANSYS-HPC$192.168.5.100:0|/data/bt2fznq7.b31  ÂFriday, January 17, 2025 05:38:55.964 AM  ÂTrue
  126    |  [2025/1/17 13:39:04]       RSM_HPC_PLATFORMSTORAGEID=/data/bt2fznq7.b31
  127    |  [2025/1/17 13:39:04]       RSM_HPC_NATIVEOPTIONS=
  128    |  [2025/1/17 13:39:04]       ARC_ROOT=/software/ansys_inc/v241/RSM/Config/scripts/../../ARC
  129    |  [2025/1/17 13:39:04]       RSM_HPC_KEYWORD=SLURM
  130    |  [2025/1/17 13:39:04]       RSM_HPC_PARSE_MARKER=START
  131    |  [2025/1/17 13:39:04]   -----------------------------------------------------------------------------
  132    |  [2025/1/17 13:39:04]   PARTITION AVAIL  TIMELIMIT  NODES  STATE NODELIST
  133    |  [2025/1/17 13:39:04]   debug*    up  infinite    2  idle c1,master
  134    |  [2025/1/17 13:39:04]   External cluster command: checkQueueExists ---------------------------------------
  135    |  [2025/1/17 13:39:04]     Cluster command before expansion: %RSM_PYTHON_EXE% -B -E "%RSM_HPC_SCRIPTS_DIRECTORY_LOCAL%/slurmParsing.py" -queues %RSM_HPC_PARSE_MARKER%
  136    |  [2025/1/17 13:39:04]     Final cluster command: /software/ansys_inc/v241/commonfiles/CPython/3_10/linx64/Release/python/runpython -B -E "/software/ansys_inc/v241/RSM/Config/scripts/slurmParsing.py" -queues START
  137    |  [2025/1/17 13:39:04]     Working directory : /data/bt2fznq7.b31
  138    |  [2025/1/17 13:39:04]     Variables:
  139    |  [2025/1/17 13:39:04]       RSM_PYTHON_HOME=/software/ansys_inc/v241/commonfiles/CPython/3_10/linx64/Release/python
  140    |  [2025/1/17 13:39:04]       RSM_IRON_PYTHON_HOME=/software/ansys_inc/v241/commonfiles/IronPython
  141    |  [2025/1/17 13:39:04]       RSM_PYTHON_EXE=/software/ansys_inc/v241/commonfiles/CPython/3_10/linx64/Release/python/runpython
  142    |  [2025/1/17 13:39:04]       RSM_TASK_WORKING_DIRECTORY=/data/bt2fznq7.b31
  143    |  [2025/1/17 13:39:04]       RSM_USE_SSH_LINUX=False
  144    |  [2025/1/17 13:39:04]       RSM_QUEUE_NAME=debug
  145    |  [2025/1/17 13:39:04]       RSM_CONFIGUREDQUEUE_NAME=Debug
  146    |  [2025/1/17 13:39:04]       RSM_COMPUTE_SERVER_MACHINE_NAME=master
  147    |  [2025/1/17 13:39:04]       RSM_HPC_JOBNAME=Mechanical
  148    |  [2025/1/17 13:39:04]       RSM_HPC_DISPLAYNAME=luosi-test-DP0---------- (A4)--------------------(A5)------------------ (A6)
  149    |  [2025/1/17 13:39:04]       RSM_HPC_CORES=8
  150    |  [2025/1/17 13:39:04]       RSM_HPC_DISTRIBUTED=TRUE
  151    |  [2025/1/17 13:39:04]       RSM_HPC_NODE_EXCLUSIVE=FALSE
  152    |  [2025/1/17 13:39:04]       RSM_HPC_QUEUE=debug
  153    |  [2025/1/17 13:39:04]       RSM_HPC_USER=admin
  154    |  [2025/1/17 13:39:04]       RSM_HPC_WORKDIR=/data/bt2fznq7.b31
  155    |  [2025/1/17 13:39:04]       RSM_HPC_JOBTYPE=Workbench_ANSYS
  156    |  [2025/1/17 13:39:04]       RSM_HPC_ANSYS_LOCAL_INSTALL_DIRECTORY=/software/ansys_inc/v241
  157    |  [2025/1/17 13:39:04]       RSM_HPC_VERSION=241
  158    |  [2025/1/17 13:39:04]       RSM_HPC_STAGING=/data/bt2fznq7.b31
  159    |  [2025/1/17 13:39:04]       RSM_HPC_LOCAL_PLATFORM=Linux
  160    |  [2025/1/17 13:39:04]       RSM_HPC_CLUSTER_TARGET_PLATFORM=Linux
  161    |  [2025/1/17 13:39:04]       RSM_HPC_STDOUTFILE=stdout_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsmout
  162    |  [2025/1/17 13:39:04]       RSM_HPC_STDERRFILE=stderr_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsmout
  163    |  [2025/1/17 13:39:04]       RSM_HPC_STDOUTLIVE=stdout_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.live
  164    |  [2025/1/17 13:39:04]       RSM_HPC_STDERRLIVE=stderr_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.live
  165    |  [2025/1/17 13:39:04]       RSM_HPC_SCRIPTS_DIRECTORY_LOCAL=/software/ansys_inc/v241/RSM/Config/scripts
  166    |  [2025/1/17 13:39:04]       RSM_HPC_SCRIPTS_DIRECTORY=$AWP_ROOT241/RSM/Config/scripts
  167    |  [2025/1/17 13:39:04]       RSM_HPC_SUBMITHOST=192.168.5.100
  168    |  [2025/1/17 13:39:04]       RSM_HPC_STORAGEID=  a15b3179-9ca0-4b8d-8bbf-b71c620eff98  Âyq4vb0am.irl=RsmSocket#ANSYS-HPC$192.168.5.100:0|/data/bt2fznq7.b31  ÂFriday, January 17, 2025 05:38:55.964 AM  ÂTrue
  169    |  [2025/1/17 13:39:04]       RSM_HPC_PLATFORMSTORAGEID=/data/bt2fznq7.b31
  170    |  [2025/1/17 13:39:04]       RSM_HPC_NATIVEOPTIONS=
  171    |  [2025/1/17 13:39:04]       ARC_ROOT=/software/ansys_inc/v241/RSM/Config/scripts/../../ARC
  172    |  [2025/1/17 13:39:04]       RSM_HPC_KEYWORD=SLURM
  173    |  [2025/1/17 13:39:04]       RSM_HPC_PARSE_MARKER=START
  174    |  [2025/1/17 13:39:04]       RSM_HPC_PRIMARY_STDOUT=PARTITION AVAIL  TIMELIMIT  NODES  STATE NODELIST
  175    |  [2025/1/17 13:39:04]   debug*    up  infinite    2  idle c1,master
  176    |  [2025/1/17 13:39:04]       RSM_HPC_PRIMARY_STDERR=
  177    |  [2025/1/17 13:39:04]   ----------------------------------------------------------------------------------
  178    |  [2025/1/17 13:39:04]   Executing command: $AWP_ROOT241/SEC/SolverExecutionController/runsec.sh  (Ansys Solver)
  179    |  [2025/1/17 13:39:04]   /data/bt2fznq7.b31/commands.xml doesn't exist to show in log
  180    |  [2025/1/17 13:39:04]   --------------- SecInput.txt file: /data/bt2fznq7.b31/SecInput.txt ---------------
  181    |  [2025/1/17 13:39:04]     #begin
  182    |  [2025/1/17 13:39:04]     Modifier
  183    |  [2025/1/17 13:39:04]     SolverTag
  184    |  [2025/1/17 13:39:04]     Ansys
  185    |  [2025/1/17 13:39:04]     #end
  186    |  [2025/1/17 13:39:04]  Â
  187    |  [2025/1/17 13:39:04]     #begin
  188    |  [2025/1/17 13:39:04]     Modifier
  189    |  [2025/1/17 13:39:04]     OperationMode
  190    |  [2025/1/17 13:39:04]     Normal
  191    |  [2025/1/17 13:39:04]     #end
  192    |  [2025/1/17 13:39:04]  Â
  193    |  [2025/1/17 13:39:04]     #begin
  194    |  [2025/1/17 13:39:04]     InputData
  195    |  [2025/1/17 13:39:04]     ProductVersion
  196    |  [2025/1/17 13:39:04]     241
  197    |  [2025/1/17 13:39:04]     #end
  198    |  [2025/1/17 13:39:04]  Â
  199    |  [2025/1/17 13:39:04]     #begin
  200    |  [2025/1/17 13:39:04]     Modifier
  201    |  [2025/1/17 13:39:04]     EnableApplicationBootstrapping
  202    |  [2025/1/17 13:39:04]     True
  203    |  [2025/1/17 13:39:04]     #end
  204    |  [2025/1/17 13:39:04]  Â
  205    |  [2025/1/17 13:39:04]     #begin
  206    |  [2025/1/17 13:39:04]     InputData
  207    |  [2025/1/17 13:39:04]     SelectivePluginList
  208    |  [2025/1/17 13:39:04]     #list
  209    |  [2025/1/17 13:39:04]     plugins.ansys
  210    |  [2025/1/17 13:39:04]     plugins.common
  211    |  [2025/1/17 13:39:04]     plugins.ekm
  212    |  [2025/1/17 13:39:04]     bootstrap.ansys
  213    |  [2025/1/17 13:39:04]     bootstrap.rsm
  214    |  [2025/1/17 13:39:04]     bootstrap.common
  215    |  [2025/1/17 13:39:04]     bootstrap.ekm
  216    |  [2025/1/17 13:39:04]     #end
  217    |  [2025/1/17 13:39:04]  Â
  218    |  [2025/1/17 13:39:04]     #begin
  219    |  [2025/1/17 13:39:04]     Modifier
  220    |  [2025/1/17 13:39:04]     EnableRsmBootstrapping
  221    |  [2025/1/17 13:39:04]     True
  222    |  [2025/1/17 13:39:04]     #end
  223    |  [2025/1/17 13:39:04]  Â
  224    |  [2025/1/17 13:39:04]     #begin
  225    |  [2025/1/17 13:39:04]     InputData
  226    |  [2025/1/17 13:39:04]     AnsysJobName
  227    |  [2025/1/17 13:39:04]     file
  228    |  [2025/1/17 13:39:04]     #end
  229    |  [2025/1/17 13:39:04]  Â
  230    |  [2025/1/17 13:39:04]     #begin
  231    |  [2025/1/17 13:39:04]     InputData
  232    |  [2025/1/17 13:39:04]     AnsysOutFileName
  233    |  [2025/1/17 13:39:04]     solve.out
  234    |  [2025/1/17 13:39:04]     #end
  235    |  [2025/1/17 13:39:04]  Â
  236    |  [2025/1/17 13:39:04]     #begin
  237    |  [2025/1/17 13:39:04]     Modifier
  238    |  [2025/1/17 13:39:04]     CaptureSolverStdout
  239    |  [2025/1/17 13:39:04]     True
  240    |  [2025/1/17 13:39:04]     #end
  241    |  [2025/1/17 13:39:04]  Â
  242    |  [2025/1/17 13:39:04]     #begin
  243    |  [2025/1/17 13:39:04]     Modifier
  244    |  [2025/1/17 13:39:04]     CaptureSolverStderr
  245    |  [2025/1/17 13:39:04]     True
  246    |  [2025/1/17 13:39:04]     #end
  247    |  [2025/1/17 13:39:04]  Â
  248    |  [2025/1/17 13:39:04]     #begin
  249    |  [2025/1/17 13:39:04]     Modifier
  250    |  [2025/1/17 13:39:04]     Distributed
  251    |  [2025/1/17 13:39:04]     On
  252    |  [2025/1/17 13:39:04]     #end
  253    |  [2025/1/17 13:39:04]  Â
  254    |  [2025/1/17 13:39:04]     #begin
  255    |  [2025/1/17 13:39:04]     Modifier
  256    |  [2025/1/17 13:39:04]     AnsysEnableSlaveNodeCopyBack
  257    |  [2025/1/17 13:39:04]     True
  258    |  [2025/1/17 13:39:04]     #end
  259    |  [2025/1/17 13:39:04]  Â
  260    |  [2025/1/17 13:39:04]     #begin
  261    |  [2025/1/17 13:39:04]     InputData
  262    |  [2025/1/17 13:39:04]     NumberOfProcesses
  263    |  [2025/1/17 13:39:04]     8
  264    |  [2025/1/17 13:39:04]     #end
  265    |  [2025/1/17 13:39:04]  Â
  266    |  [2025/1/17 13:39:04]     #begin
  267    |  [2025/1/17 13:39:04]     InputData
  268    |  [2025/1/17 13:39:04]     NumberOfThreadsPerProcess
  269    |  [2025/1/17 13:39:04]     0
  270    |  [2025/1/17 13:39:04]     #end
  271    |  [2025/1/17 13:39:04]  Â
  272    |  [2025/1/17 13:39:04]     #begin
  273    |  [2025/1/17 13:39:04]     InputData
  274    |  [2025/1/17 13:39:04]     Arguments
  275    |  [2025/1/17 13:39:04]     -b nolist -s noread -apip off -p ansys -i remote.dat -o solve.out
  276    |  [2025/1/17 13:39:04]     #end
  277    |  [2025/1/17 13:39:04]  Â
  278    |  [2025/1/17 13:39:04]   --------------- SecInput.txt file END ---------------
  279    |  [2025/1/17 13:39:04]   External cluster command: submit ---------------------------------------
  280    |  [2025/1/17 13:39:04]     Cluster command before expansion: sbatch -p %RSM_HPC_QUEUE% --ntasks=%RSM_HPC_CORES% -J "%RSM_HPC_JOBNAME%" %RSM_HPC_NATIVEOPTIONS% --export=ALL -o "%RSM_HPC_STAGING%/%RSM_HPC_STDOUTFILE%" -e "%RSM_HPC_STAGING%/%RSM_HPC_STDERRFILE%" "%RSM_HPC_STAGING%/%RSM_HPC_COMMAND%"
  281    |  [2025/1/17 13:39:04]     Final cluster command: sbatch -p debug --ntasks=8 -J "Mechanical"  --export=ALL -o "/data/bt2fznq7.b31/stdout_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsmout" -e "/data/bt2fznq7.b31/stderr_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsmout" "/data/bt2fznq7.b31/clusterjob_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.sh"
  282    |  [2025/1/17 13:39:04]     Working directory : /data/bt2fznq7.b31
  283    |  [2025/1/17 13:39:04]     Variables:
  284    |  [2025/1/17 13:39:04]       RSM_PYTHON_HOME=/software/ansys_inc/v241/commonfiles/CPython/3_10/linx64/Release/python
  285    |  [2025/1/17 13:39:04]       RSM_IRON_PYTHON_HOME=/software/ansys_inc/v241/commonfiles/IronPython
  286    |  [2025/1/17 13:39:04]       RSM_PYTHON_EXE=/software/ansys_inc/v241/commonfiles/CPython/3_10/linx64/Release/python/runpython
  287    |  [2025/1/17 13:39:04]       RSM_TASK_WORKING_DIRECTORY=/data/bt2fznq7.b31
  288    |  [2025/1/17 13:39:04]       RSM_USE_SSH_LINUX=False
  289    |  [2025/1/17 13:39:04]       RSM_QUEUE_NAME=debug
  290    |  [2025/1/17 13:39:04]       RSM_CONFIGUREDQUEUE_NAME=Debug
  291    |  [2025/1/17 13:39:04]       RSM_COMPUTE_SERVER_MACHINE_NAME=master
  292    |  [2025/1/17 13:39:04]       RSM_HPC_JOBNAME=Mechanical
  293    |  [2025/1/17 13:39:04]       RSM_HPC_DISPLAYNAME=luosi-test-DP0---------- (A4)--------------------(A5)------------------ (A6)
  294    |  [2025/1/17 13:39:04]       RSM_HPC_CORES=8
  295    |  [2025/1/17 13:39:04]       RSM_HPC_DISTRIBUTED=TRUE
  296    |  [2025/1/17 13:39:04]       RSM_HPC_NODE_EXCLUSIVE=FALSE
  297    |  [2025/1/17 13:39:04]       RSM_HPC_QUEUE=debug
  298    |  [2025/1/17 13:39:04]       RSM_HPC_USER=admin
  299    |  [2025/1/17 13:39:04]       RSM_HPC_WORKDIR=/data/bt2fznq7.b31
  300    |  [2025/1/17 13:39:04]       RSM_HPC_JOBTYPE=Workbench_ANSYS
  301    |  [2025/1/17 13:39:04]       RSM_HPC_ANSYS_LOCAL_INSTALL_DIRECTORY=/software/ansys_inc/v241
  302    |  [2025/1/17 13:39:04]       RSM_HPC_VERSION=241
  303    |  [2025/1/17 13:39:04]       RSM_HPC_STAGING=/data/bt2fznq7.b31
  304    |  [2025/1/17 13:39:04]       RSM_HPC_LOCAL_PLATFORM=Linux
  305    |  [2025/1/17 13:39:04]       RSM_HPC_CLUSTER_TARGET_PLATFORM=Linux
  306    |  [2025/1/17 13:39:04]       RSM_HPC_STDOUTFILE=stdout_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsmout
  307    |  [2025/1/17 13:39:04]       RSM_HPC_STDERRFILE=stderr_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsmout
  308    |  [2025/1/17 13:39:04]       RSM_HPC_STDOUTLIVE=stdout_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.live
  309    |  [2025/1/17 13:39:04]       RSM_HPC_STDERRLIVE=stderr_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.live
  310    |  [2025/1/17 13:39:04]       RSM_HPC_SCRIPTS_DIRECTORY_LOCAL=/software/ansys_inc/v241/RSM/Config/scripts
  311    |  [2025/1/17 13:39:04]       RSM_HPC_SCRIPTS_DIRECTORY=$AWP_ROOT241/RSM/Config/scripts
  312    |  [2025/1/17 13:39:04]       RSM_HPC_SUBMITHOST=192.168.5.100
  313    |  [2025/1/17 13:39:04]       RSM_HPC_STORAGEID=  a15b3179-9ca0-4b8d-8bbf-b71c620eff98  Âyq4vb0am.irl=RsmSocket#ANSYS-HPC$192.168.5.100:0|/data/bt2fznq7.b31  ÂFriday, January 17, 2025 05:38:55.964 AM  ÂTrue
  314    |  [2025/1/17 13:39:04]       RSM_HPC_PLATFORMSTORAGEID=/data/bt2fznq7.b31
  315    |  [2025/1/17 13:39:04]       RSM_HPC_NATIVEOPTIONS=
  316    |  [2025/1/17 13:39:04]       ARC_ROOT=/software/ansys_inc/v241/RSM/Config/scripts/../../ARC
  317    |  [2025/1/17 13:39:04]       RSM_HPC_KEYWORD=SLURM
  318    |  [2025/1/17 13:39:04]       RSM_HPC_COMMAND=clusterjob_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.sh
  319    |  [2025/1/17 13:39:04]       RSM_HPC_PARSE_MARKER=START
  320    |  [2025/1/17 13:39:04]   ------------------------------------------------------------------------
  321    |  [2025/1/17 13:39:04]   Submitted batch job 10
  322    |  [2025/1/17 13:39:04]   External cluster command: parseSubmit ---------------------------------------
  323    |  [2025/1/17 13:39:04]     Cluster command before expansion: %RSM_PYTHON_EXE% -B -E "%RSM_HPC_SCRIPTS_DIRECTORY_LOCAL%/slurmParsing.py" -submit %RSM_HPC_PARSE_MARKER%
  324    |  [2025/1/17 13:39:04]     Final cluster command: /software/ansys_inc/v241/commonfiles/CPython/3_10/linx64/Release/python/runpython -B -E "/software/ansys_inc/v241/RSM/Config/scripts/slurmParsing.py" -submit START
  325    |  [2025/1/17 13:39:04]     Working directory : /data/bt2fznq7.b31
  326    |  [2025/1/17 13:39:04]     Variables:
  327    |  [2025/1/17 13:39:04]       RSM_PYTHON_HOME=/software/ansys_inc/v241/commonfiles/CPython/3_10/linx64/Release/python
  328    |  [2025/1/17 13:39:04]       RSM_IRON_PYTHON_HOME=/software/ansys_inc/v241/commonfiles/IronPython
  329    |  [2025/1/17 13:39:04]       RSM_PYTHON_EXE=/software/ansys_inc/v241/commonfiles/CPython/3_10/linx64/Release/python/runpython
  330    |  [2025/1/17 13:39:04]       RSM_TASK_WORKING_DIRECTORY=/data/bt2fznq7.b31
  331    |  [2025/1/17 13:39:04]       RSM_USE_SSH_LINUX=False
  332    |  [2025/1/17 13:39:04]       RSM_QUEUE_NAME=debug
  333    |  [2025/1/17 13:39:04]       RSM_CONFIGUREDQUEUE_NAME=Debug
  334    |  [2025/1/17 13:39:04]       RSM_COMPUTE_SERVER_MACHINE_NAME=master
  335    |  [2025/1/17 13:39:04]       RSM_HPC_JOBNAME=Mechanical
  336    |  [2025/1/17 13:39:04]       RSM_HPC_DISPLAYNAME=luosi-test-DP0---------- (A4)--------------------(A5)------------------ (A6)
  337    |  [2025/1/17 13:39:04]       RSM_HPC_CORES=8
  338    |  [2025/1/17 13:39:04]       RSM_HPC_DISTRIBUTED=TRUE
  339    |  [2025/1/17 13:39:04]       RSM_HPC_NODE_EXCLUSIVE=FALSE
  340    |  [2025/1/17 13:39:04]       RSM_HPC_QUEUE=debug
  341    |  [2025/1/17 13:39:04]       RSM_HPC_USER=admin
  342    |  [2025/1/17 13:39:04]       RSM_HPC_WORKDIR=/data/bt2fznq7.b31
  343    |  [2025/1/17 13:39:04]       RSM_HPC_JOBTYPE=Workbench_ANSYS
  344    |  [2025/1/17 13:39:04]       RSM_HPC_ANSYS_LOCAL_INSTALL_DIRECTORY=/software/ansys_inc/v241
  345    |  [2025/1/17 13:39:04]       RSM_HPC_VERSION=241
  346    |  [2025/1/17 13:39:04]       RSM_HPC_STAGING=/data/bt2fznq7.b31
  347    |  [2025/1/17 13:39:04]       RSM_HPC_LOCAL_PLATFORM=Linux
  348    |  [2025/1/17 13:39:04]       RSM_HPC_CLUSTER_TARGET_PLATFORM=Linux
  349    |  [2025/1/17 13:39:04]       RSM_HPC_STDOUTFILE=stdout_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsmout
  350    |  [2025/1/17 13:39:04]       RSM_HPC_STDERRFILE=stderr_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsmout
  351    |  [2025/1/17 13:39:04]       RSM_HPC_STDOUTLIVE=stdout_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.live
  352    |  [2025/1/17 13:39:04]       RSM_HPC_STDERRLIVE=stderr_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.live
  353    |  [2025/1/17 13:39:04]       RSM_HPC_SCRIPTS_DIRECTORY_LOCAL=/software/ansys_inc/v241/RSM/Config/scripts
  354    |  [2025/1/17 13:39:04]       RSM_HPC_SCRIPTS_DIRECTORY=$AWP_ROOT241/RSM/Config/scripts
  355    |  [2025/1/17 13:39:04]       RSM_HPC_SUBMITHOST=192.168.5.100
  356    |  [2025/1/17 13:39:04]       RSM_HPC_STORAGEID=  a15b3179-9ca0-4b8d-8bbf-b71c620eff98  Âyq4vb0am.irl=RsmSocket#ANSYS-HPC$192.168.5.100:0|/data/bt2fznq7.b31  ÂFriday, January 17, 2025 05:38:55.964 AM  ÂTrue
  357    |  [2025/1/17 13:39:04]       RSM_HPC_PLATFORMSTORAGEID=/data/bt2fznq7.b31
  358    |  [2025/1/17 13:39:04]       RSM_HPC_NATIVEOPTIONS=
  359    |  [2025/1/17 13:39:04]       ARC_ROOT=/software/ansys_inc/v241/RSM/Config/scripts/../../ARC
  360    |  [2025/1/17 13:39:04]       RSM_HPC_KEYWORD=SLURM
  361    |  [2025/1/17 13:39:04]       RSM_HPC_COMMAND=clusterjob_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.sh
  362    |  [2025/1/17 13:39:04]       RSM_HPC_PARSE_MARKER=START
  363    |  [2025/1/17 13:39:04]       RSM_HPC_PRIMARY_STDOUT=Submitted batch job 10
  364    |  [2025/1/17 13:39:04]       RSM_HPC_PRIMARY_STDERR=
  365    |  [2025/1/17 13:39:04]   -----------------------------------------------------------------------------
  366    |  [2025/1/17 13:39:04]   JobId was parsed as: 10
  367    |  [2025/1/17 13:39:09]   Job submission was successful.
  368    |  [2025/1/17 13:39:05]   Job is running on hostname c1
  369    |  [2025/1/17 13:39:05]   Job user from this host: admin
  370    |  [2025/1/17 13:39:05]   Starting directory: /data/bt2fznq7.b31
  371    |  [2025/1/17 13:39:05]   Reading control file /data/bt2fznq7.b31/control_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsm ....
  372    |  [2025/1/17 13:39:05]   Correct Cluster verified
  373    |  [2025/1/17 13:39:05]   Cluster Type: SLURM
  374    |  [2025/1/17 13:39:05]   Underlying Cluster: SLURM
  375    |  [2025/1/17 13:39:05]     RSM_CLUSTER_TYPE = SLURM
  376    |  [2025/1/17 13:39:05]   Compute Server is running on MASTER
  377    |  [2025/1/17 13:39:05]   Reading commands and arguments...
  378    |  [2025/1/17 13:39:05]     Command 1: $AWP_ROOT241/SEC/SolverExecutionController/runsec.sh, arguments: , redirectFile: None
  379    |  [2025/1/17 13:39:05]   Running from shared staging directory ...
  380    |  [2025/1/17 13:39:05]     RSM_USE_LOCAL_SCRATCH = False
  381    |  [2025/1/17 13:39:05]     RSM_LOCAL_SCRATCH_DIRECTORY =
  382    |  [2025/1/17 13:39:05]     RSM_LOCAL_SCRATCH_PARTIAL_UNC_PATH =
  383    |  [2025/1/17 13:39:05]   Cluster Shared Directory: /data/bt2fznq7.b31
  384    |  [2025/1/17 13:39:05]     RSM_SHARE_STAGING_DIRECTORY = /data/bt2fznq7.b31
  385    |  [2025/1/17 13:39:05]   Job file clean up: False
  386    |  [2025/1/17 13:39:05]   Use SSH on Linux cluster nodes: False
  387    |  [2025/1/17 13:39:05]     RSM_USE_SSH_LINUX = False
  388    |  [2025/1/17 13:39:05]   LivelogFile: NOLIVELOGFILE
  389    |  [2025/1/17 13:39:05]   StdoutLiveLogFile: stdout_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.live
  390    |  [2025/1/17 13:39:05]   StderrLiveLogFile: stderr_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.live
  391    |  [2025/1/17 13:39:05]   Reading input files...
  392    |  [2025/1/17 13:39:05]     *.cgns
  393    |  [2025/1/17 13:39:05]     *.dat
  394    |  [2025/1/17 13:39:05]     *.mac
  395    |  [2025/1/17 13:39:05]     *.swf
  396    |  [2025/1/17 13:39:05]     cp*.*
  397    |  [2025/1/17 13:39:05]     file*.*
  398    |  [2025/1/17 13:39:05]     knockdown.ist
  399    |  [2025/1/17 13:39:05]     thermal.build
  400    |  [2025/1/17 13:39:05]     SecInput.txt
  401    |  [2025/1/17 13:39:05]     nlad_mesh_input.msh
  402    |  [2025/1/17 13:39:05]     nlad_mesh_input.asc
  403    |  [2025/1/17 13:39:05]     *.comps
  404    |  [2025/1/17 13:39:05]     *.par
  405    |  [2025/1/17 13:39:05]     *.rth
  406    |  [2025/1/17 13:39:05]     commands.xml
  407    |  [2025/1/17 13:39:05]   Reading cancel files...
  408    |  [2025/1/17 13:39:05]     sec.interrupt
  409    |  [2025/1/17 13:39:05]   Reading output files...
  410    |  [2025/1/17 13:39:05]     *.NR*
  411    |  [2025/1/17 13:39:05]     *.bswf
  412    |  [2025/1/17 13:39:05]     *.swf
  413    |  [2025/1/17 13:39:05]     *.xml
  414    |  [2025/1/17 13:39:05]     *apip.json
  415    |  [2025/1/17 13:39:05]     AMHighStrain.txt
  416    |  [2025/1/17 13:39:05]     AMResults.txt
  417    |  [2025/1/17 13:39:05]     CAERepOutput.xml
  418    |  [2025/1/17 13:39:05]     Harmonic*.h5
  419    |  [2025/1/17 13:39:05]     Harmonic*.vtk
  420    |  [2025/1/17 13:39:05]     Load_*.inp
  421    |  [2025/1/17 13:39:05]     Modal*.h5
  422    |  [2025/1/17 13:39:05]     Modal*.vtk
  423    |  [2025/1/17 13:39:05]     Mode_mapping_*.txt
  424    |  [2025/1/17 13:39:05]     NotSupportedElems.dat
  425    |  [2025/1/17 13:39:05]     ObjectiveHistory.out
  426    |  [2025/1/17 13:39:05]     PostImage*.png
  427    |  [2025/1/17 13:39:05]     RemotePostInformation.txt
  428    |  [2025/1/17 13:39:05]     Static*.h5
  429    |  [2025/1/17 13:39:05]     Static*.vtk
  430    |  [2025/1/17 13:39:05]     cyclic_map.json
  431    |  [2025/1/17 13:39:05]     exit.topo
  432    |  [2025/1/17 13:39:05]     file*.dsub
  433    |  [2025/1/17 13:39:05]     file*.ldhi
  434    |  [2025/1/17 13:39:05]     file*.mntr
  435    |  [2025/1/17 13:39:05]     file*.png
  436    |  [2025/1/17 13:39:05]     file*.r0*
  437    |  [2025/1/17 13:39:05]     file*.r1*
  438    |  [2025/1/17 13:39:05]     file*.r2*
  439    |  [2025/1/17 13:39:05]     file*.r3*
  440    |  [2025/1/17 13:39:05]     file*.r4*
  441    |  [2025/1/17 13:39:05]     file*.r5*
  442    |  [2025/1/17 13:39:05]     file*.r6*
  443    |  [2025/1/17 13:39:05]     file*.r7*
  444    |  [2025/1/17 13:39:05]     file*.r8*
  445    |  [2025/1/17 13:39:05]     file*.r9*
  446    |  [2025/1/17 13:39:05]     file*.rd*
  447    |  [2025/1/17 13:39:05]     file*.rst
  448    |  [2025/1/17 13:39:05]     file*.sub
  449    |  [2025/1/17 13:39:05]     file.BCS
  450    |  [2025/1/17 13:39:05]     file.DSP
  451    |  [2025/1/17 13:39:05]     file.PCS
  452    |  [2025/1/17 13:39:05]     file.ce
  453    |  [2025/1/17 13:39:05]     file.cm
  454    |  [2025/1/17 13:39:05]     file.cnd
  455    |  [2025/1/17 13:39:05]     file.cnm
  456    |  [2025/1/17 13:39:05]     file.err
  457    |  [2025/1/17 13:39:05]     file.gst
  458    |  [2025/1/17 13:39:05]     file.json
  459    |  [2025/1/17 13:39:05]     file.nd*
  460    |  [2025/1/17 13:39:05]     file.nlh
  461    |  [2025/1/17 13:39:05]     file.nr*
  462    |  [2025/1/17 13:39:05]     file.rdb
  463    |  [2025/1/17 13:39:05]     file.rfl
  464    |  [2025/1/17 13:39:05]     file.spm
  465    |  [2025/1/17 13:39:05]     file0.BCS
  466    |  [2025/1/17 13:39:05]     file0.PCS
  467    |  [2025/1/17 13:39:05]     file0.ce
  468    |  [2025/1/17 13:39:05]     file0.cnd
  469    |  [2025/1/17 13:39:05]     file0.err
  470    |  [2025/1/17 13:39:05]     file0.gst
  471    |  [2025/1/17 13:39:05]     file0.nd*
  472    |  [2025/1/17 13:39:05]     file0.nlh
  473    |  [2025/1/17 13:39:05]     file0.nr*
  474    |  [2025/1/17 13:39:05]     frequencies_*.out
  475    |  [2025/1/17 13:39:05]     input.x17
  476    |  [2025/1/17 13:39:05]     intermediate*.topo
  477    |  [2025/1/17 13:39:05]     knockdown.ist
  478    |  [2025/1/17 13:39:05]     morphed*.stl
  479    |  [2025/1/17 13:39:05]     post.out
  480    |  [2025/1/17 13:39:05]     record.txt
  481    |  [2025/1/17 13:39:05]     solve*.out
  482    |  [2025/1/17 13:39:05]     structured_history.xml
  483    |  [2025/1/17 13:39:05]     topo.err
  484    |  [2025/1/17 13:39:05]     topo.out
  485    |  [2025/1/17 13:39:05]     topo_cyclic_map.txt
  486    |  [2025/1/17 13:39:05]     vars.topo
  487    |  [2025/1/17 13:39:05]     sec.validation.executed
  488    |  [2025/1/17 13:39:05]     *.comps
  489    |  [2025/1/17 13:39:05]     *.par
  490    |  [2025/1/17 13:39:05]     *.rth
  491    |  [2025/1/17 13:39:05]   Reading exclude files...
  492    |  [2025/1/17 13:39:05]     stdout_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsmout
  493    |  [2025/1/17 13:39:05]     stderr_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsmout
  494    |  [2025/1/17 13:39:05]     control_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsm
  495    |  [2025/1/17 13:39:05]     hosts.dat
  496    |  [2025/1/17 13:39:05]     exitcode_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsmout
  497    |  [2025/1/17 13:39:05]     exitcodeCommands_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsmout
  498    |  [2025/1/17 13:39:05]     stdout_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.live
  499    |  [2025/1/17 13:39:05]     stderr_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.live
  500    |  [2025/1/17 13:39:05]     ClusterJobCustomization.xml
  501    |  [2025/1/17 13:39:05]     ClusterJobs.py
  502    |  [2025/1/17 13:39:05]     clusterjob_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.sh
  503    |  [2025/1/17 13:39:05]     clusterjob_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.bat
  504    |  [2025/1/17 13:39:05]     inquire.request
  505    |  [2025/1/17 13:39:05]     inquire.confirm
  506    |  [2025/1/17 13:39:05]     request.upload.rsm
  507    |  [2025/1/17 13:39:05]     request.download.rsm
  508    |  [2025/1/17 13:39:05]     wait.download.rsm
  509    |  [2025/1/17 13:39:05]     scratch.job.rsm
  510    |  [2025/1/17 13:39:05]     volatile.job.rsm
  511    |  [2025/1/17 13:39:05]     restart.xml
  512    |  [2025/1/17 13:39:05]     cancel_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsmout
  513    |  [2025/1/17 13:39:05]     liveLogLastPositions_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsm
  514    |  [2025/1/17 13:39:05]     stdout_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf_kill.rsmout
  515    |  [2025/1/17 13:39:05]     stderr_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf_kill.rsmout
  516    |  [2025/1/17 13:39:05]     sec.interrupt
  517    |  [2025/1/17 13:39:05]     stdout_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf_*.rsmout
  518    |  [2025/1/17 13:39:05]     stderr_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf_*.rsmout
  519    |  [2025/1/17 13:39:05]     stdout_task_*.live
  520    |  [2025/1/17 13:39:05]     stderr_task_*.live
  521    |  [2025/1/17 13:39:05]     control_task_*.rsm
  522    |  [2025/1/17 13:39:05]     stdout_task_*.rsmout
  523    |  [2025/1/17 13:39:05]     stderr_task_*.rsmout
  524    |  [2025/1/17 13:39:05]     exitcode_task_*.rsmout
  525    |  [2025/1/17 13:39:05]     exitcodeCommands_task_*.rsmout
  526    |  [2025/1/17 13:39:05]   Reading environment variables...
  527    |  [2025/1/17 13:39:05]     RSM_IRON_PYTHON_HOME = /software/ansys_inc/v241/commonfiles/IronPython
  528    |  [2025/1/17 13:39:05]     RSM_TASK_WORKING_DIRECTORY = /data/bt2fznq7.b31
  529    |  [2025/1/17 13:39:05]     RSM_USE_SSH_LINUX = False
  530    |  [2025/1/17 13:39:05]     RSM_QUEUE_NAME = debug
  531    |  [2025/1/17 13:39:05]     RSM_CONFIGUREDQUEUE_NAME = Debug
  532    |  [2025/1/17 13:39:05]     RSM_COMPUTE_SERVER_MACHINE_NAME = master
  533    |  [2025/1/17 13:39:05]     RSM_HPC_JOBNAME = Mechanical
  534    |  [2025/1/17 13:39:05]     RSM_HPC_DISPLAYNAME = luosi-test-DP0---------- (A4)--------------------(A5)------------------ (A6)
  535    |  [2025/1/17 13:39:05]     RSM_HPC_CORES = 8
  536    |  [2025/1/17 13:39:05]     RSM_HPC_DISTRIBUTED = TRUE
  537    |  [2025/1/17 13:39:05]     RSM_HPC_NODE_EXCLUSIVE = FALSE
  538    |  [2025/1/17 13:39:05]     RSM_HPC_QUEUE = debug
  539    |  [2025/1/17 13:39:05]     RSM_HPC_USER = admin
  540    |  [2025/1/17 13:39:05]     RSM_HPC_WORKDIR = /data/bt2fznq7.b31
  541    |  [2025/1/17 13:39:05]     RSM_HPC_JOBTYPE = Workbench_ANSYS
  542    |  [2025/1/17 13:39:05]     RSM_HPC_ANSYS_LOCAL_INSTALL_DIRECTORY = /software/ansys_inc/v241
  543    |  [2025/1/17 13:39:05]     RSM_HPC_VERSION = 241
  544    |  [2025/1/17 13:39:05]     RSM_HPC_STAGING = /data/bt2fznq7.b31
  545    |  [2025/1/17 13:39:05]     RSM_HPC_LOCAL_PLATFORM = Linux
  546    |  [2025/1/17 13:39:05]     RSM_HPC_CLUSTER_TARGET_PLATFORM = Linux
  547    |  [2025/1/17 13:39:05]     RSM_HPC_STDOUTFILE = stdout_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsmout
  548    |  [2025/1/17 13:39:05]     RSM_HPC_STDERRFILE = stderr_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.rsmout
  549    |  [2025/1/17 13:39:05]     RSM_HPC_STDOUTLIVE = stdout_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.live
  550    |  [2025/1/17 13:39:05]     RSM_HPC_STDERRLIVE = stderr_0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf.live
  551    |  [2025/1/17 13:39:05]     RSM_HPC_SCRIPTS_DIRECTORY_LOCAL = /software/ansys_inc/v241/RSM/Config/scripts
  552    |  [2025/1/17 13:39:05]     RSM_HPC_SCRIPTS_DIRECTORY = /software/ansys_inc/v241/RSM/Config/scripts
  553    |  [2025/1/17 13:39:05]     RSM_HPC_SUBMITHOST = 192.168.5.100
  554    |  [2025/1/17 13:39:05]     RSM_HPC_STORAGEID =  a15b3179-9ca0-4b8d-8bbf-b71c620eff98  Âyq4vb0am.irl=RsmSocket#ANSYS-HPC$192.168.5.100:0|/data/bt2fznq7.b31  ÂFriday, January 17, 2025 05:38:55.964 AM  ÂTrue
  555    |  [2025/1/17 13:39:05]     RSM_HPC_PLATFORMSTORAGEID = /data/bt2fznq7.b31
  556    |  [2025/1/17 13:39:05]     RSM_HPC_NATIVEOPTIONS =
  557    |  [2025/1/17 13:39:05]     ARC_ROOT = /software/ansys_inc/v241/RSM/Config/scripts/../../ARC
  558    |  [2025/1/17 13:39:05]     RSM_HPC_KEYWORD = SLURM
  559    |  [2025/1/17 13:39:05]     RSM_PYTHON_LOCALE = en-us
  560    |  [2025/1/17 13:39:05]   Reading AWP_ROOT environment variable name ...
  561    |  [2025/1/17 13:39:05]     AWP_ROOT environment variable name is: AWP_ROOT241
  562    |  [2025/1/17 13:39:05]   Reading Low Disk Space Warning Limit ...
  563    |  [2025/1/17 13:39:05]     Low disk space warning threshold set at: 2.0GiB
  564    |  [2025/1/17 13:39:05]   Reading File identifier ...
  565    |  [2025/1/17 13:39:05]     File identifier found as: 0f54d8b6-140f-4cfa-b5dd-c065f9f62fbf
  566    |  [2025/1/17 13:39:05]   Done reading control file.
  567    |  [2025/1/17 13:39:11]   RSM_AWP_ROOT_NAME = AWP_ROOT241
  568    |  [2025/1/17 13:39:11]   AWP_ROOT241 install directory: /software/ansys_inc/v241
  569    |  [2025/1/17 13:39:11]   SLURM_JOB_NODELIST = c1,master<
  570    |  [2025/1/17 13:39:11]   SLURM_TASKS_PER_NODE = 4(x2)<
  571    |  [2025/1/17 13:39:11]   RSM_MACHINES = c1:4:master:4
  572    |  [2025/1/17 13:39:11]   ALTERNATE_MACHINES = c1:4:master:4
  573    |  [2025/1/17 13:39:11]   Number of nodes assigned for current job = 2
  574    |  [2025/1/17 13:39:11]   Machine list: ['c1', 'master']
  575    |  [2025/1/17 13:39:11]   Start running job commands ...
  576    |  [2025/1/17 13:39:11]   Running on machine : c1
  577    |  [2025/1/17 13:39:11]   Current Directory: /data/bt2fznq7.b31
  578    |  [2025/1/17 13:39:11]   Running command: /software/ansys_inc/v241/SEC/SolverExecutionController/runsec.sh
  579    |  [2025/1/17 13:39:11]   Redirecting output to  None
  580    |  [2025/1/17 13:39:11]   Final command arg list : ['/software/ansys_inc/v241/SEC/SolverExecutionController/runsec.sh']
  581    |  [2025/1/17 13:39:11]   Running Process
  582    |  [2025/1/17 13:39:11]   Running Solver : /software/ansys_inc/v241/ansys/bin/ansys241 -b nolist -s noread -apip off -p ansys -i remote.dat -o solve.out -dis -machines c1:4:master:4 -dir "/data/bt2fznq7.b31"
  583    |  [2025/1/17 13:39:35]   Determine the Mellanox Infiniband OFED version number
  584    |  [2025/1/17 13:39:35]   Determine if the user is running on Amazon Web Servers EFA interconnect
  585    |  [2025/1/17 13:39:35]   NOTE: Mellanox OFED version has not been detected on this system.  Intel MPI 2018 being automatically used.
  586    |  [2025/1/17 13:39:41]   unknown option -- -
  587    |  [2025/1/17 13:39:41]   usage: ssh [-46AaCfGgKkMNnqsTtVvXxYy] [-B bind_interface]
  588    |  [2025/1/17 13:39:41]        [-b bind_address] [-c cipher_spec] [-D [bind_address:]port]
  589    |  [2025/1/17 13:39:41]        [-E log_file] [-e escape_char] [-F configfile] [-I pkcs11]
  590    |  [2025/1/17 13:39:41]        [-i identity_file] [-J [user@]host[:port]] [-L address]
  591    |  [2025/1/17 13:39:41]        [-l login_name] [-m mac_spec] [-O ctl_cmd] [-o option] [-p port]
  592    |  [2025/1/17 13:39:41]        [-Q query_option] [-R address] [-S ctl_path] [-W host:port]
  593    |  [2025/1/17 13:39:41]        [-w local_tun[:remote_tun]] destination [command]
Hello, this is all the information。
5284
1885
1403
1267
