HOW TO CREATE PLANE IN RESULT FILE OF ANSYS FLUENT
    • rajdipjag
      HOW TO CREATE PLANE IN RESULT FILE OF ANSYS FLUENT WHEN PHYSICAL DOMAIN IS 3-DIMENSIONAL.
      I tend to use an isosurface of mesh and then set to x, y or z values to suit my needs.  If you open up mesh, contours or vector panels it's under the New Surface menu. I'd also suggest going though the tutorials as it should be covered there.
    • Keyur Kanade
      You can use Post processing - create - isosurface. Please select Mesh and then select x, y or z direction
  • The topic ‘HOW TO CREATE PLANE IN RESULT FILE OF ANSYS FLUENT’ is closed to new replies.
