January 9, 2021 at 6:47 pm
Rajdeep_11
SubscriberJanuary 9, 2021 at 9:59 pmpeteroznewman
SubscribernOn the Facets tab, use the Separate All button to make a separate facet body for each interior cavity.nSeparate the facet bodies using Components (may be an optional step?).nShrinkwrap each facet body one at a time.nOn the Design tab, use the Combine tool to subtract the interior solids from the exterior solid to recreate the cavities.nJanuary 10, 2021 at 11:07 pmRajdeep_11
Subscriberthe seperate all function didn't work when I selected the whole geometry. Once I cut out the bounding faces and then used it, it created individual facets. Not all of them could be shrinkwrapped(those ones I deleted). I converted the remaining shrink-wrapped bodies into solids and tried to subtract it from a cube of dimensions same as the bounding box but it showed errors. nJanuary 10, 2021 at 11:11 pmJanuary 11, 2021 at 4:24 ampeteroznewman
SubscribernYou can create solid geometry then convert that to a Facet Body.nYou can use a Facet Surface to cut a Facet Body.nYou have to learn all the tools on the Facet tab,nTry to do one pore at a time.nIt is a tedious process.nnJanuary 11, 2021 at 8:43 amRajdeep_11
SubscriberOkay I shall give some time to it and update you. Thanks again for your kind help!nViewing 5 reply threads- The topic ‘How to Create Geometry from STL files preserving inner features.’ is closed to new replies.
5289
1885
1403
1267
