July 16, 2020 at 6:47 am
matus
SubscriberHai
How to create an XY plot of the average value of the fluid temperature across the cross-section of the pipe to the axial length of the pipe?
July 17, 2020 at 5:32 am
Keyur Kanade
Ansys EmployeeTo create a plot you will need to create a line first. You can create a line use results --> create --> line
Then you can use this line for xy plot.Â
For more information please check help document atÂ
Also check following.Â
https://www.youtube.com/watch?v=SsORGWCg1ss
https://www.youtube.com/watch?v=Chv4QhOLO-g
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
- The topic ‘How to create an XY plot of average value of the temperature of fluid across the cross-section?’ is closed to new replies.
1306
