How to create a workbench journal file
    • sadaspire
      I am trying to run a FSI simulation using the system coupling set up in the Workbench. In order to speed up the sim, I plan to use the HPC but I have been struggling to create a journal file from the Workbench. Below is what I created so far using automatic creation. Could anyone know how to write the journal file for the system coupling in Workbench? Thank you for your help in advance.
      # encoding: utf-8
      # Release 18.1
      SetScriptVersion(Version="18.1.463")
      template1 = GetTemplate(TemplateName="System Coupling")
      system1 = GetSystem(Name="FFF")
      system2 = template1.CreateSystem(
          Position="Right",
          RelativeTo=system1)
      setupComponent1 = system1.GetComponent(Name="Setup")
      setupComponent2 = system2.GetComponent(Name="Setup")
      setupComponent1.TransferData(TargetComponent=setupComponent2)
      system3 = GetSystem(Name="SYS")
      setupComponent3 = system3.GetComponent(Name="Setup")
      setupComponent3.TransferData(TargetComponent=setupComponent2)
      setupComponent1.Update(AllDependencies=True)
      setup1 = system1.GetContainer(ComponentName="Setup")
      setup1.SendCommand(Command='(cx-gui-do cx-set-list-tree-selections "NavigationPane*List_Tree1" (list ))')
      setupComponent3.Update(AllDependencies=True)
      setupComponent2.Refresh()
      setup2 = system2.GetContainer(ComponentName="Setup")
      AnalysisSettings1 = setup2.GetAnalysisSettings()
      AnalysisSettings1.EndTime = "500 "
      AnalysisSettings1.StepSize = "0.5 "
      dataTransfer1 = setup2.CreateDataTransfer(Name="Data Transfer")
      dataTransfer2 = setup2.CreateDataTransfer(Name="Data Transfer 2")
      participant1 = setup2.GetParticipant(Name="Solution 1")
      dataTransfer1.SetEntityProperties(Properties=Set(SourceParticipant=participant1, SourceRegion=None, SourceVariable=None))
      region1 = participant1.GetRegion(Name="fsi")
      dataTransfer1.SetEntityProperties(Properties=Set(SourceRegion=region1, SourceVariable=None))
      variable1 = GetDataEntity("/Setup 2/SystemCouplingVariable:force")
      dataTransfer1.SetEntityProperties(Properties=Set(SourceVariable=variable1))
      participant2 = setup2.GetParticipant(Name="Solution")
      dataTransfer1.SetEntityProperties(Properties=Set(TargetParticipant=participant2, TargetRegion=None, TargetVariable=None))
      region2 = participant2.GetRegion(Name="FSIN_1")
      dataTransfer1.SetEntityProperties(Properties=Set(TargetRegion=region2, TargetVariable=None))
      variable1 = GetDataEntity("/Setup 2/SystemCouplingVariable:FORC")
      dataTransfer1.TargetVariable = variable1
      dataTransfer2.SetEntityProperties(Properties=Set(SourceParticipant=participant2, SourceRegion=None, SourceVariable=None))
      dataTransfer2.SetEntityProperties(Properties=Set(SourceRegion=region2, SourceVariable=None))
      variable1 = GetDataEntity("/Setup 2/SystemCouplingVariable:INCD")
      dataTransfer2.SetEntityProperties(Properties=Set(SourceVariable=variable1))
      dataTransfer2.SetEntityProperties(Properties=Set(TargetParticipant=participant1, TargetRegion=None, TargetVariable=None))
      dataTransfer2.SetEntityProperties(Properties=Set(TargetRegion=region1, TargetVariable=None))
      variable1 = GetDataEntity("/Setup 2/SystemCouplingVariableisplacement")
      dataTransfer2.TargetVariable = variable1
      intermediateResultFilesOutputControls1 = setup2.GetIntermediateRestartDataOutputControls()
      intermediateResultFilesOutputControls1.OutputFrequency = "StepInterval"
      intermediateResultFilesOutputControls1.StepInterval = 5
    • sadaspire
      Hi Peter,
      Thank you for your reply.
      Please find the attached Workbench project file. It would be appreciated to give me some advice.
      Cheers,
      Sorry, I can't help. I have never used journal files.
  • The topic ‘How to create a workbench journal file’ is closed to new replies.
