How to create a valid path in I Beam.Please help to remove this error. Cam someone help me with this
December 1, 2020 at 8:28 pm
Umarfarooq46
SubscriberDecember 1, 2020 at 10:24 pmpeteroznewman
SubscribernDelete the item in the outline with the ? under the Solution branch.nWhat do you need a path for? What are you trying to plot?nDecember 2, 2020 at 9:47 amUmarfarooq46
Subscriberi want to run analysis on i beam.nDecember 2, 2020 at 12:21 pmpeteroznewman
SubscriberDelete the Linearized Equivalent Stress plot and the analysis will run.nViewing 3 reply threads- The topic ‘How to create a valid path in I Beam.Please help to remove this error. Cam someone help me with this’ is closed to new replies.
5899
1306
