February 28, 2026 at 11:45 pm
2mudrt52
SubscriberHi,
I’m running ANSYS Fluent 2025 R2 with Fluent Meshing → Watertight Geometry Workflow only (university license). I’m simulating VOF free-surface (air/water, open-channel) flow through a plastic collection net (fishing net basically)+flow around floating solid to measure the drag. I need to model a thin net panel inside the fluid domain as a Porous Jump (pressure loss only), but the panel is internal (does not touch outer boundaries).
Problem: I struggle to create a robust porous-jump setup without the case failing. To assign porous jump, I tried:
- splitting the fluid domain into 2 volumes and using the split plane as internal,
- imprinting/splitting the net patch on the internal plane,
- applying share topology / joining, etc.
But I often get “pairs not joined” on the internal interface, zones disappear/merge after meshing, and porous-jump ends up as a wall or cannot be assigned cleanly.
Question: What is the recommended, fail-safe workflow in Watertight Geometry to create an internal surface for a net and assign it as Porous Jump for VOF open-channel cases?
Specifically: should this be done as a baffle (wall + shadow), an internal face zone, or by splitting into two cell zones and making a mesh interface—what’s the most robust method in Fluent 2025 R2 which later also doesn't cause solver issues ?
Thanks!
5279
1885
1403
1262
