Materials
Materials
Topics related to Granta Design and more.
how to create a composite material with only E1, E2, v12 and G12 property?
    • Chin-Hung Lai
      Because in CLT plane element don't consider the direction of Z axial. I used ACP and transform to shell element, but if i change the value of G23, the result won't be the same. but i should be the same. why? can anyone help me? thanks.
    • Reno Genest
      The out-of-plane shear stiffnesses G31 and G23 are involved via shear correction factors:
      [46] P. Isaksson, A. Krusper, and P.A. Gradin. Shear Correction Factors for Corrugated Core Structures. Composite Structures. Vol. 80. pp. 123-130. 2007.
      The above is taken from the Ansys documentation:
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/acp_ug/Out-of-Plane_Shear_Moduli_and_CF.html
      Reno.
  • The topic ‘how to create a composite material with only E1, E2, v12 and G12 property?’ is closed to new replies.
