How to copy Geometry and Mesh file from one Ansys Workbench project to another?
    • smalbro93
      I just can't seem to figure out how to do this. Here is what I have tried:nI have tried copying mesh and geometry file from previous project directory into the SYS folder of the new workbench project folder but when I run the Workbench project file then the files are automatically deleted.nI tried to import the geometry file separately and it worked but then I cannot import the Mesh file next. (I need to re-do the meshing on the geometry)nI tried importing the mesh directly but the imported mesh is un-editable in workbench.nI want to import the mesh and geometry into a separate workbench project and be able to edit the mesh as well. Is there a way we can do that ?nIf it is the same Workbench project then we can duplicate the mesh and geometry but what if we want to do the same but in different workbench project. Thanks.n
      You can save as on the project then delete the bits you don't want. If you want to edit the mesh export the meshdat from Meshing (File-Export). That contains enough of the geometry to allow remeshing. n
  • The topic ‘How to copy Geometry and Mesh file from one Ansys Workbench project to another?’ is closed to new replies.
