August 26, 2019 at 11:39 am
wangwang
SubscriberThanks for reading.
I already know that my project would need user defined command, in other word, APDL in the next step.
Now, my current project is about impacting and I want to achieve a cohesive behavior during the process. I am using Explicit Dynamics analysis component in Workbench. But I find that there is not a embeded cohesive behavior inside of Explicit Dyanmics and I couldn't insert APDL in Explicit Dynamics module.
So, how can I convert my solution in Ansys Mechanical? Because I heard about that Ansys mechanical or Ansys APDL could solve project from a bottom aspect, like you could always select your element type and input user defined command.
Thanks for suggestion.
August 26, 2019 at 6:14 pm
tsiriaks
Ansys EmployeeI would recommend to post this question in Physics Simulation -> Structural Mechanics section to get more attention.
Thanks,
Win
- The topic ‘How to convert solution in Workbench/Explicit Dynamics in Ansys Mechanical?’ is closed to new replies.
4077
1487
